looking at sda srs
sda2mike
sda2mike Posts: 3,131
edited October 2011 in Vintage Speakers
they're about an hour and change south of me. so i need the guru's to pipe in;) they have the pin/blade...the xover plate has 8 screws on the outside edge... i had the seller pull inner and outer drivers..the inner mw is a 6505 with the marking: srs 1.2....the outer has 6511 sda 1c...they are dated sept and oct 1988...can these be tl'd...i offered 800 he came back with a grand...what do you guys think?
thanks!
mike
Post edited by sda2mike on
  • joeparaski
    joeparaski Posts: 1,865
    edited October 2011
    If they are in good shape then I'd go for it at that price.
    Joe
    Amplifiers: 1-SAE Mark IV, 4-SAE 2400, 1-SAE 2500, 2-SAE 2600, 1-Buttkicker BKA 1000N w/2-tactile transducers. Sources: Sony BDP CX7000es, Sony CX300/CX400/CX450/CX455, SAE 8000 tuner, Akai 4000D R2R, Technics 1100A TT, Epson 8500UB with Carada 100". Speakers:Polk SDA SRS, 3.1TL, FXi5, FXi3, 2-SVS 20-29, Yamaha, SVS center sub. Power:2-Monster HTS3500, Furman M-8D & RR16 Plus. 2-SAE 4000 X-overs, SAE 5000a noise reduction, MSB Link DAC III, MSB Powerbase, Behringer 2496, Monarchy DIP 24/96.
  • sda2mike
    edited October 2011
    looks like somebody did!!! i was local...this buyer is in cali!! someday...
  • michaeljhsda2
    michaeljhsda2 Posts: 2,186
    edited October 2011
    They are at minimum 1.2's (and can be TL'd with the appropriate mods) because they have a pin/blade IC socket. They're 1.2TL's if they have the SL3000 tweeters.
    SDA SRS 2.3TL's
    SDA 2B TL's
