Jensen Transformers Sub and Digital Cable TV Isolation Transformers
Face
For sale from Jensen Transformers, their sub and digital cable TV Isolation Transformers, SUB-1RR and VRD-1FF. Since upgrading my pre-pro and installing dedicated outlets, I no longer have any use for these items.
I'm asking $60 shipped CONUS for the SUB-1RR and $40 shipped CONUS for the VRD-1FF.
Please PM me if you have any questions.
Post edited by Face on
Ttt..."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I will confirm that the VRD-1FF cable isolator works perfectly. It also does not interfere with reception of the HD channels or use of on-demand like many cheaper ones. Free bump!
May be interested in the CATV isolation transformer. If I run interconnects from my integrated to my cable box, I get a ground loop/buzz. It seems that any electrical connection to anything connected to my cable gives me buzz, so I've been running optical; but only have one optical input. By placing it between my outlet and cable box, the hum should go away, correct?
I'll answer that with a resounding yes. It is clear that you are having a ground loop due to your cable having a different ground than your electricity; the same problem I have as well. I will enthusiastically recommend these, as they get rid of the hum/buzz and they do not interfere with your ability to receive all of your channels or VOD.May be interested in the CATV isolation transformer. If I run interconnects from my integrated to my cable box, I get a ground loop/buzz. It seems that any electrical connection to anything connected to my cable gives me buzz, so I've been running optical; but only have one optical input. By placing it between my outlet and cable box, the hum should go away, correct?
