Dynamat vs Fatmat
Michael8it
Michael8it Posts: 197
edited December 2011 in DIY, Mods & Tweaks
I am getting closer to my 12B overhaul and found an alternative product to Dynamat called fatmat . I wanted to know if anyone has had any experience with this product. is is far less expensive than Dynamat, and since in this particular application, we are only looking to stop vibration, not block noise (which is what Dynamat is also designed to do), this should work fine. Actually, Felt or even silicone caulk would probably work to stop the speaker basket from vibrating, although caulk would be a mess to apply.
Please let me know if you have had any experience with this product.
Carver C-1, M-500 MKII, Yamaha HTR-5835, Polk RTA 12BM's (M-for mod'd).
  • drumminman
    drumminman Posts: 3,396
    edited October 2011
    Michael8it wrote: »
    I've used both and I can't tell that there's any difference when damping speaker baskets. They look very similar, too.
  • Michael8it
    edited October 2011
    Thanks. I assumed that was the case - and I can get 10 sq ft for $20 shipped. That is far less than Dynamat!
    F1nut Posts: 52,406
    edited October 2011
    We are looking to stop/block both as one is the same as the other. Dynamat Extreme appears to be thicker and therefore will do a better job.
  • brgman
    brgman Posts: 2,859
    edited October 2011
    I use only Dynamat Extreme.
    Dozens,if not hundreds of polkies went that route and i consider it the standard for the application.just my opinion.
    I’M OFFENDED!!!!
  • jbooker82
    jbooker82 Posts: 1,627
    edited October 2011
    I just used a dynamat wedge kit. It is like a 4 foot roll and it was enough to do my RTI A7's and CSI A4.
    Your talking about putting it on the magnet shields and basket fingers right?
    $24.50
    http://www.ebay.com/itm/DYNAMAT-10425-XTREME-EXTREME-CAR-WEDGE-PACK-PAK-SOUND-DEADENING-DEADENER-DAMPING-?cmd=ViewItem&hash=item53e97c2a79&item=360399514233&pt=LH_DefaultDomain_0
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • teamjhertz
    teamjhertz Posts: 363
    edited October 2011
    I am just giving another option from my car audio days. One of the best rated products that I used was http://www.raamaudio.com/. Another alternative would be http://secondskinaudio.com/
  • Esreuter
    Esreuter Posts: 176
    edited October 2011
    Evening Michael,
    to add to the mix, I have fat matted all my polks and it worked wonders from the moment I applied it.
    I think you could get away perfectly with the fat mat and save yourself some $$ for later overhauls.
    My 2 cents for ya, make sure to spend them wisely, we are in a recession.:lol:
    ESR :smile:
    AVR: Sony 5600ES
    Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
    Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    More to come :biggrin:
  • Michael8it
    edited October 2011
    Yes, this is to dampen vibration on the speaker baskets (magnet shields and fingers). Everyone that has done this said it made a tremendous difference. I happened across the FatMat product and thought it would do the same job for a lot less.
  • jbooker82
    edited October 2011
    Michael8it wrote: »
    Just wanted to make sure. I dont my RTI A7's and CSI A4 with a dynamat wedge kit. It cost like 24 bucks and done all 3 speakers.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • chadam44
    chadam44 Posts: 68
    Very similar, but cheaper. Either will do the job, but if you can save some coin, I would (and have) gone that route.
