Need thoughts on finding optimum speaker placement, and speaker choices
gmcman
gmcman Posts: 1,849
edited December 2013 in Speakers
What I have is not the ideal listening room, but unfortunately unless I take out some permits...I need to make the best of it.
The room is rectangular with 8' ceilings, an equilateral triangle as a sweet spot has turned into quite the isoceles. I thought of relocating the door into the spare room to the left but the HVAC ducting will leave some head scars.
I have a couch on the left wall and the 2nd smaller couch is turned sideways as my main seating position, however it's roughly 17' from the speakers.
The room is 158" wide (13'2) with the speakers next to the TV, they are 64" apart (5'4") If I place the right speaker near the wall, then they are 90" apart ( 7'6")
The room is 23' long so that puts the seating position 6' from the rear wall, which consists of a fireplace in the center. I've been asking around about this room but want to ask the Polkies since that will likely stay as my main gear. I have some rockwool so I can build some panels at varying thickness up to 3 1/2"
I'm also currently looking for a pair of SDA's so before I finalize a pair, I would also like to know if what I have is either doable or just not worth having SDA's alongside of trying to make regular speakers work.
My fronts are RT800's with a CS400 center, I can move some things around but obviously i'm limited.
There are a few more kids toys but for the most part this is what I have, the cat tree has been replaced with legos and such.
Also the slider does have a thick curtain for it.
Post edited by gmcman on
  • quadzilla
    quadzilla Posts: 1,543
    edited October 2011
    Those other doors go to the rest of the house, yes? If so, I'd start with centering everything on the back wall. Also, the seating is wrong for HT. The seating should be aligned with the front sound stage. It doesn't have to be, but you're never going to get good surround with the seating on the side walls.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • gmcman
    gmcman Posts: 1,849
    edited October 2011
    quadzilla wrote: »
    I have the small couch from the right turned sideways and is facing the TV, which is 6' from the rear wall. My bad..I should have been clearer on that.
  • gmcman
    gmcman Posts: 1,849
    edited October 2011
    Could I get a pair of SDA-2A's to work in this room if I take the current speaker location and aim towards the center of the room?
    The listening position will be roughly right next to the right edge of the dark coffee table.
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    I didn't realize this was the room your were talking about. I think the 2B's would work better for you. I actually think the original SDA2 would be a bit bass heavy in your configuration. Corner loading the SDA2 is tricky and usually yields a boomy bass situation. You would loose some mid detail with them. The SDA2B's would be easier to place and give your more detail than either 1C's or SDA2 orig.
    Can you give us a shot of the other end of the room? How against moving things around are you?
    I would place a speaker where the cat tree is and try to straighten your whole system out a bit. Just a thought.
  • gmcman
    gmcman Posts: 1,849
    edited October 2011
    It makes all the sense to center everything and walk around to the door, but for now I need to keep it offset to the right.
    The right speaker is now against the tv, giving it some breathing room...that's where the SDA will sit also.
  • gmcman
    gmcman Posts: 1,849
    edited November 2011
    Wanted to update that I went with the 2B...love em.
    Allright....after debating this for awhile..I think i'm going to center everything and add a door to the back room. I still want to use the door behind the TV but only if needed...don't want to block the entire wall.
    Not sure if I should build a wall unit to house the components or just use a rack on one side. Would like access to the door but keep the TV, speakers, and components on the same plane...i'm open to all suggestions.
    Another area is room treatment.
    Going on a rough estimate for a RT60 chart, I came up with neding 8 panels 24"x48"x2" for this room....does this sound like alot?
    I have about 8 pieces of rockwool left over from a project to make panels, don't think 8 panels would look right.
    Does the size of the panels matter or just total sq.ft? I thought about running a strip down the narrow side of the HVAC duct along the left side which would give me a consideral amount of absorbing material.
    What about sound absorbing paint? This is something I could possibly apply to the ceiling.
  • jbooker82
    jbooker82 Posts: 1,627
    Heck the door behined the tv would be so you can get behind the equipment with out moving it, bonus.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    F1nut Posts: 51,787
    That's not wide enough for SDA's. You need a minimum of 15'. I'd put the rig along the long wall where the big sofa is now.
  • gmcman
    gmcman Posts: 1,849
    F1....you're not the only one who has told me that.
    I was hoping I could make the narrow wall work if I moved the couch within 12' of the rig.
    The long wall can work......I just need to get rid of the conveyed "Holly Hobbie" couch, not that I'm complaining too much.
    My main concern was being too close to the set, CRT RPTV's don't have a great off-axis viewing angle, and I love that set.
    That would put me 10' from the display panel, close but could possibly work.
  • gmcman
    gmcman Posts: 1,849
    Heres another thought.....would there be an effective way of adding sound panels to the side walls where the TV is now, that would "falslely" create a wider room, almost like adding polyfill to a sub box?
    Would this deteriorate the SDA effect too much?
    Just a thought, would like to explore and discuss all possibilities.
  • Joe08867
    gmcman wrote: »
    No the panels will just dull the room which is probably already dull being carpeted as it is. The long wall is your better bet. Plus the TV will look huge sitting that much closer.
  • rebuy
    rebuy Posts: 695
    What kind of TV is that?
  • gmcman
    gmcman Posts: 1,849
    rebuy wrote: »
    Hitachi 57X500
  • rebuy
    rebuy Posts: 695
    The reason I was asking was because it did look like a rear projection TV. Having viewed these types it seems you have to be at a certain distance from them to get the best viewing experience. If having the TV on a long wall opposite the couch, would that make the TV too close for viewing?
  • drummer86
    drummer86 Posts: 441
    gmcman wrote: »
    Hitachi 57X500
    Had that exact tv in college. Loved it. Great set.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • mccarty250
    mccarty250 Posts: 220
    Agreed, placement is not optimal for SDA's unfortunately.
