PSW505 disassembly
brokenarrow03
Hey quick question...
I am having some issues with my PSW505 and after testing the amp, I was advised by Polk Audio to check to see if the speaker was maybe disconnected. Problem is I don't know how to get at the speaker without damaging the black casing around the outside of the speaker to get at the screws.
Any Advice?
Any Advice?
Post edited by brokenarrow03 on
Hello,
That is a decorative gasket, just pull it off and you'll see the screws underneath. Polk CS can send a replacement that can be put back in place.
Cheers, Ken
