Rti a1 first impressions
Well I finally received my new fronts today, out of the box the mid bass blows away the energy cb5's the replaced. The mode and high do seem pretty weak though. I noticed I need to go much higher on the receiver volume as well. I haven't run audyssey yet and I'm gonna wait to fully break them in before I give a full revirw. Hopefully they will loosen up a bit
Post edited by 1QWK510 on
Also quick question they came with 2 screws are they for wall mounting them they seem a little small.
Congrats on the A1s - nice speaker.
Definitely re-run Audessey. You'd have to compare speaker efficiency to see if the A1 is more/less efficient that your previous energy speaker.
You may also find that you need to experiment with Audessey to get the best setup (diff sound modes and PEQ profiles).
The screws are for wall mounting - should be fine if you use then on a wall stud - definitely won't work on just drywall.
Yeah I'm gonna rerun audyessy today. The speakers are both rated at 89db so I think they just need to break in. And yes there mounted to a.wall stud.
Quick update, after a few more hours things have really changed. These speakers sound awesome! I'm am very happy with the purchase.
RTI A's get better with age.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
Full 8.2 with:
Onkyo TX-NR818
Emotiva XPA-3
Audiosource Amp One/A
Behringer EPQ2000 w/quietfan mod
Panny BDP310
3TB NAS
Ethereal ESP601R
Monster HTS 1650
Epson HC-3020
120" DIY 1.0 Gain Screen
Polk Rti A9 fronts
Polk Rti 6 surrounds
Polk Rt/Fx rear surrounds
Polk Rti 4 front heights
(Phantom center)
SVS 12's x 2 (DIY passive):eek:
ATS Acoustics DIY panels
Harmony 650
Nostalgia Electronics CCP-510 MovieTime Popcorn Cart
