HK-730 Short Review
stubby
stubby Posts: 723
edited October 2011 in Vintage Speakers
So I fetched my CRS speakers out of the closet and hooked them up to the fairly heavy duty spring clip connectors on the back of my newly acquired Harmon Kardon HK-730 receiver. Backwards. Not really paying attention, I hooked the right channel speaker up to the right set of connectors, and the left to left. Wrong. Counter-intuitively, the connector pairs are reversed on the back panel. Plainly marked, but ignored by me.
After reversing my mistake, I listened and could not believe the quality of sound produced by this receiver. The CRS's were hitting low notes like never berfore - even as they were pulled away from the rear wall by about 2 feet. Quick, punchy bass. Mids and highs were smooth but also very articulate. Lots of detail. And bare in mind, this is through an old Onkyo 6 disc changer with cheap ICs and Walmart speaker cable. (not proud, but...) I am very impressed by this HK.
Will try it on the SRS2's later and report back.
stubby
SRS 3.1TL
Harman Kardon Citation 5.1
Anthem AVM2
Post edited by stubby on
    mhardy6647 Posts: 35,350
    edited October 2011
    stubby wrote: »
    ... I listened and could not believe the quality of sound produced by this receiver. The CRS's were hitting low notes like never berfore - even as they were pulled away from the rear wall by about 2 feet...
    Out of curiosity, to what amplifier's LF performance are you comparing the CRS bass vis-a-vis your comment above?
  • stubby
    stubby Posts: 723
    edited October 2011
    An Acurus A-200 matched with an Audiolab 8000Q preamp.
    SRS 3.1TL
    Anthem AVM2
  • stubby
    stubby Posts: 723
    edited October 2011
    Ya know, I'll be the first to admit that I have a spec bias. IOW, an amp's spec sheet is something I pay close attention to if I am considering it for my system. Well, those days are over. I hooked the HK receiver up to the SRS2s and was completely blown away. This thing had the same neutral to warm mids and clarity as my Acurus/Audiolab equipment - PLUS it probably went another half octave lower in the bass. And I am talking quality bass - quick tight and punchy.
    Now I am completely re-evaluating my system as far as amplification. Man this is a fun hobby!
    stubby
    SRS 3.1TL
    Anthem AVM2
