LSi9 Components
loudmouth
loudmouth Posts: 6
edited October 2011 in 2 Channel Audio
Hello,
I am looking into an integrated amp to run my lsi9's through.
I have $5000 and want the speakers to sound AS GOOD as humanly possible.
Today had a chance to listen to a naim 5i and krell S-300i. Both below budget.
I liked the sound of the 5i. It sounded warm and gave the speakers pleanty of power.
The Krell. Eh. It sounded more mechanical? Idk, but after hearing the 9's on the 5i, I have been hooked on that Naim "House Sound".
So, my question to you is;
Will a Supernait or... Superuniti (or the xs?) be what I am looking for as far as power and options go? (My dealer doesn't carry any of these models)
2 channel only (mostly music via turntable)
sub addition (someday)
optical input for xbox audio (my main dvd/cd audio component)
phono (stageline phonostage)
aux for cable audio.
Maybe a blu-ray player in the future? Maybe a seperate power amp? Depends.
So PLease Please Please! let me know if you have any info on these integrates on hooked up with polk lsi9 speakers.
Post edited by loudmouth on
  • loudmouth
    loudmouth Posts: 6
    edited October 2011
    Supernait:
    Input Sensitivity
    75mV
    Input Impedance
    47kΩ
    Sample Rates Supported
    S/PDIF up to 24 bit/192kHz
    Other Inputs
    3.5mm jack on front panel
    AUDIO OUTPUTS
    Line Outputs Fixed (level)
    75mV, 600Ω
    Line Outputs Variable (level)
    775mV, <50Ω
    Power Outputs
    Naim phono amplifier
    Other Outputs
    Headphone, 3.5mm jack
    SPEAKER OUTPUTS
    Power Output
    80W/channel, 8Ω
    CONNECTIVITY
    Infra Red
    RC5
    Remote Input
    3.5mm jack on rear (RC5)
    Remote Output
    RS232
    Optional (DE9 female)
    POWER
    Mains Supply
    100V, 115V, 230V; 50 or 60Hz
    PHYSICAL
    Dimensions
    87 x 432 x 314mm (H x W x D)
    and Superuniti:
    Analogue Inputs
    1 x 5-pin DIN, 2 x RCA pair, 1 x 3.5mm front panel jack
    Input Sensitivity
    170mV
    Overload Margin
    34dB
    Input Impedance
    47k
    Digital Inputs
    6 x S/PDIF (1 x coaxial BNC, 1 x coaxial RCA, 3 x optical TOSlink, 1 x 3.5mm front panel mini-TOSlink)
    Sample rates maximum
    192kHz (coaxial) 96kHz (optical)
    Bit depths maximum
    24 bits
    UPnP input
    Ethernet (RJ45) and Wi-Fi
    USB/iPod input
    Front panel USB Type-A
    Playlist supported
    M3U and PLS
    FM and DAB input
    F-type
    Tuning Range
    FM 87.5 - 108MHz, DAB Band III and L Band
    iRadio input
    Service provider
    Vtuner 5*
    Minimum Load Impedance
    10kΩ
    FORMATS
    Audio Formats Supported
    WAV and AIFF (up to 32bit/192kHz) FLAC (up to 24bit/192kHz) ALAC (up to 24bit/96kHz) WMA (up to 16bit/48kHz) must be WMA 9.2 Ogg Vorbis (up to 16bit/48kHz) MP3 and M4a (up to 320kbit/s)
    WMA, MP3, MMS
    SPEAKER OUTPUTS
    Speaker Outputs
    Stereo (4mm)
    AUDIO OUTPUTS
    Output power
    80Wpc into 8Ω, 120Wpc into 4Ω(0.1% THD both channel driven)
    Frequency Response
    3.5Hz to 34kHz
    Signal To Noise Ratio (S/N ratio)
    85dB
    Crosstalk
    80dB
    Phase Response
    Linear Phase, absolute phase correct
    Headphone outputs
    Stereo (front panel 3.5mm jack)
    Output power
    105mW into 16Ω
    Other analogue outputs
    Preamp output (4-pin DIN), Subwoofer output (RCA pair)
    Digital Outputs (type)
    S/PDIF (coaxial BNC 75Ω)
    USER CONTROL INTERFACES
    Front Panel
    Volume control, logo mute and buttons
    Remote
    Uniti family remote
    iPod/iPhone/iPad
    n-Stream
    AMX & Crestron
    Yes
    CONNECTIVITY
    Infra Red
    Front panel
    Remote Input
    RC5 input (3.5mm rear panel jack)
    Remote Output
    RS232
    Updates only (rear panel USB mini-B)
    PRODUCT CERTIFICATIONS & LICENSES
    Certifications
    Apple (Made for iPhone), vTuner Premium
    Licenses
    MP3, AAC, DAB
    POWER
    Mains Supply
    100V, 115V or 230V, 50/60Hz
    Quiescent consumption
    35W
    Maximum consumption
    400VA
    Supplied accessories
    Wi-fi antenna, Uniti family remote handset, batteries, BNC to RCA adaptor,F-type to PAL adaptor, mains lead, speaker plugs.
    I notice that the uniti is 4 ohm rated. I'm not sure but if it is the same with the supernait and they just didn't reveal that it is capable of a 4 ohm load I am definately leaning more towards the supernait. I like the option of upgrading the power supply, (flatcap/hicap/supercap)
    Also, if you want to suggest any other brands/combos i should try, please do.
    I am nothing but confused as this is my first dabble into this wounderful hobby and this will be my first setup. (other than some crappy samsung theater in-a-box christmas present) thank you again and goodday goodsir
    VR3 Posts: 29,387
    edited October 2011
    5k? Lsi9?
    I highly recommend replacing the speakers then getting new components.
    No offense to the LSi9 - but if you were to source speakers in the 2k range - you could easily get some 3k components to blow your mind...
    IMO of course - if the LSi9 is a MUST then follow your ears
    F1nut Posts: 51,673
    edited October 2011
    Musical Fidelity M6 500i integrated amplifier. If you can find one used, it'll fit your budget.
  • punit
    punit Posts: 8
    edited October 2011
    I would heartily recommend the NAD M3
    http://nadelectronics.com/products/masters-series/M3-Dual-Mono-Integrated-Amplifier
    I would also recommend upgrading the crossovers on the LSI9, I upgraded mine & consider it one of the best audio investments i ever made. Here's a link for the same :
    http://www.polkaudio.com/forums/showthread.php?97029-Skiing-Ninja-crossover-upgrade
    MAC Mini 3.1, OSX 10.6, 2.53 GHZ, Intel Core 2 Duo with SSD & 6 GB Ram, Audio GD NFB-7,2009 Macbook Pro 15" 4 gb ram OS 2.5 Ghz X 10.5.8, Apogee Duet, Signal Cable Silver Resolution Cables & power chords through out the system,Isotek GII Vision, Polk Audio LSI9 speakers (2 pairs, one with Custom external crossover by Sking Ninja), Cayin / Spark AT70 integrated amp, Audio GD Master 1 pre amp, Rotel RB1080 power amp.
  • loudmouth
    loudmouth Posts: 6
    edited October 2011
    Ok, Vr3MxStyler2k3, if i were to, say, return my lsi9s, buy some b&w pm1's (first love) for 2k whats a possible component choice for 3k? In my area there is a mcintosh dealer, a marantz dealer and they carry some other products like krell, naim, rotel, parasound, ayre, among others. I would prefer to buy from one of them so I can, you know, get repairs add-ons, special deals, things like that.
    F1nut Posts: 51,673
    edited October 2011
    Why don't you drag your Polk's down to the dealer and try them out on whatever integrated amps they have on hand.
    Those are about as far apart, sound wise, as you can get. Personally, I've never heard a B&W speaker that I could stand.
    Another thought, there are crossover upgrades that elevate the LSi 9's to a much higher performance level. Perhaps you might want to look into that. Polk also has the new LSiM 703's.
  • loudmouth
    loudmouth Posts: 6
    edited October 2011
    I did do this and thats where I came to this conclusion: Naim and Krell were nice sounding integates for a reasonable price.
    And I am assuming that is why you are not a part of B&W forums. I bought the lsi9's on a recomendation. they were very cheap and i am not disappointed with the way they sound, thus i felt no reason to return them.
    Like I said, i prefer a B&W speaker to polks, so the new LSiM's wont be in my near future. i have heard several people recomend the crossover upgrade. What exactly happens to the speaker once you do this? It would null and void my warrenty right?
  • markmarc
    markmarc Posts: 2,309
    edited October 2011
    The Sim Audio Moon i7 integrated you can find used in the $3500 range. Better resolution than Musical Fidelity units IMHO. Then put the rest towards upgrading the LSi9 x-over for $600 with the Skiing Ninja x-overs, or by one of the good polkers. Sticking with the stock LSi9's is truly limiting your sonic experience with the financial investment you're about to make.
    Very very few speakers need warranty repair unless you plan on running pure distortion or plan on blasting them with weak amplification at ridiculous volume levels thru the speakers. With the x-over the 9's high end opens up tremendously, demonstrating the true quality of the Vifa tweeter. The mids and bass become more resolving. It's worth every penny.
    Former Staff Member TONEAudio
    2 Ch. System
    VR3 Posts: 29,387
    edited October 2011
    I hate to say this but you are seriously limiting your options by sticking with local dealers in this respect...
    Salk Sound, Tyler Acoustics, Odyssey Audio, GR Research, Nuforce, Monarchy Audio, VMPS is just a few in a pool of many low cost high performance out there...
    The Polk LSiM would be an excellent basis for a system of that caliber - I just think you can do much better than the LSi9 if you are willing to sink that much $$$ into the gear to support it...
    The used market really opens up the options even further...
    Im sure for what would equate to 6 grand you could find a setup that would rock your world...
    At one point I had the following -
    Tyler Acoustics Taylo 7u - 2600
    Odyssey Candela - 1200
    Odyssey Stratos Extreme Monoblocks - 1500
    Shanling CDT-100 CDP - 1000
    Thats - 6300
    Just an example - but there are so many options out there and gear can be had cheap... companies like Odyssey offer a 20 year transferable warranty
    Bryston is another good one...
    Pass Labs - etc etc
