Anyone ever use these for securing drivers to the enclosure?
mlhm5
mlhm5 Posts: 217
edited October 2011 in Vintage Speakers
Post edited by mlhm5 on
    heiney9 Posts: 25,217
    edited October 2011
    How would you use those? Have you looked at the recessed baffle cut-out? Based on this photo there is no room to use these. The recessed cut out lip is not wide enough to drill a hole to use these. Even if by a slim chance they were, there wouldn't be enough wood fiber left to properly anchor these inserts. If they aren't anchored properly as soon as you put any kind of torque on the bolts to hold the drivers these would surely pull out.
    I am basing this on the photo, because those look rather large, perhaps in real life they aren't.
  • Face
    Face Posts: 14,340
    edited October 2011
    They work well with drivers that have a large flange, such as large woofers, some mids and tweeters.
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2011
    I'd never use those for any speakers, good way to ruined speakers (especially old ones where the chip wood has expanded and is brittle). I've seen the damage those can do in furnitures and other cheap press board manufacturing.
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • OldmanSRS
    OldmanSRS Posts: 419
    edited October 2011
    There is some kind of screw-in metal insert in the MDF for securing the XO plate (and I think the drivers too) on my 1.2's. I had to run one of them back in with an allen wrench after taking off the XO plate. I think they are the same as in your photo.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
    nooshinjohn Posts: 25,465
    edited October 2011
    Larry's rings are the most elegant solution. I will stick with them.
  • drumminman
    drumminman Posts: 3,396
    edited October 2011
    Hurricane nuts from Parts Express also work very well, should Larry not have rings available. The 8-32's with 1" cap head socket screws and 4 mm stainless steel washers are ideal for almost any Polk cabinets. :cool:
  • Mr. Bubbles
    Mr. Bubbles Posts: 736
    edited October 2011
    These were in all locations in my SRS's. I first thought they were something that a previous owner had added until i found one stuck in the factory glue that had inadvertently fell into the enclosure while being built. I am with Technokid I would not use these on anything. I removed all and replaced with T-nuts. I am attaching some pics of what i found in my cabinets.
    here you can see them in the cabinets
    this is the one I found in the glue
    this is the damage they can cause. This was located at one of the crossover mounting holes.
    There are much better options. Though I haven't personally used them I would think Larry's rings would be the best option if they are available for your model. T-nuts would be a close second.
    Toolfan66 Posts: 17,338
    edited October 2011
    Yep those were in my 1.2tl's as well and most would work there way out a little. I would pass on them my self!!! if the rings are not for you use the T-nuts!!
    Polk Audio SDA 2.3tl Fully Hot Rodded. 😎
    SVS SB16 X2
    Cary SLP-05/Ultimate Upgrade.
    Cary SA-500.1 ES Amps
    Cary DMS 800PV Network
    Jolida JD9 Fully Modified
    VPI MW-1 Cyclone RCM
    MIT Shotgun 3 cables throughout / Except TT, and PC’s
  • Face
    Face Posts: 14,340
    edited October 2011
    I wouldn't use them in press board either. They work fine in MDF and hard woods though as long as you drill the correct size pilot hole.
  • adcomcyclone
    adcomcyclone Posts: 49
    edited October 2011
    My SRS have these in the bottom plate to mount the feet/spikes in. I assume they are standard there since the bottom plate is hardwood, though I suppose they could have been added by prior owner.
    Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
    Home Theatre
    Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
    Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
    Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    Hurricane Nuts or Larry's rings would be your best bet. Those things look like they would cause to much damage to me.
