How Loud?
thesurfer
thesurfer Posts: 574
edited October 2011 in The Clubhouse
What volume do you guys normally listen to your music, Im usually between 9,oclock and 10,
Not an Audiophile, just a dude who loves music, and decent gear to hear it with.
Post edited by thesurfer on
  • Joe08867
    Joe08867 Posts: 3,919
    edited October 2011
    I usually play it at about 1/3 up to 1/2 on the dial between the hours of 7-11pm most nights.
  • Drenis
    Drenis Posts: 2,871
    edited October 2011
    My volume knob just keeps turning!!:eek:
    But I usually settle for anywhere between -20 to -5. -2 to 0 are for showing off... and even THAT'S too loud.
  • WilliamM2
    WilliamM2 Posts: 4,773
    edited October 2011
    Position of the dial or db displayed will be different on every system for any given volume.
  • thsmith
    thsmith Posts: 6,082
    edited October 2011
    using SPL meter I prefer 85-87db
  • brgman
    brgman Posts: 2,859
    edited October 2011
    I think 85-90db is good for someone with good (normal) hearing.
    I tend to run at 95-100 due to spending much of 10 years at the soundboard of a band and also going to about a thousand live shows without ear protection.
    I’M OFFENDED!!!!
  • kuntasensei
    kuntasensei Posts: 3,263
    edited October 2011
    WilliamM2 wrote: »
    Well, not if you calibrate to reference level with an SPL meter so 0 = 105dB/115dB LFE.
    My normal listening level is about -15dB, which means peaks of 90dB from the main channels and 100dB from the LFE channel. But sometimes, that gets bumped up a bit if I'm showing off a good action flick. :wink:
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • BlueFox
    BlueFox Posts: 15,251
    edited October 2011
    thesurfer wrote: »
    That level means absolutely nothing to anyone else. Generally, for dedicated listening at a distance of approximately 8 feet from speakers I keep it in the 70+db range, with dips into the 60s and peaks into the 80s. Once you consistently get into the 80s and higher you have lost the ability to have a conversation without shouting.
  • Oldfatdogs
    Oldfatdogs Posts: 1,874
    edited October 2011
    Hay surfer,in one of my threads you said you enjoy insulting people from your front porch.You should keep the volume down so they can hear you.:razz:Dan
  • thesurfer
    edited October 2011
    Oldfatdogs wrote: »
    Yes Dan, im always sure to have it low when im out front talking smack, wouldnt want anyone to miss any of my clever comebacks,
  • evhudsons
    evhudsons Posts: 1,175
    edited October 2011
    I just got a hd tv calibration disk today to calibrate my projector. I've read here and everywhere about these numbers spl an such. Where do you recommend I start researching this stuff as I want to calibrate my audio setup if it is in my budget.
  • brgman
    brgman Posts: 2,859
    edited October 2011
    BlueFox wrote: »
    Conversation? I'm anti-social when i am "listening" to music.If i'm having a conversation then the music is just background fluff.
    I’M OFFENDED!!!!
  • WilliamM2
    edited October 2011
    While that would make them the same level at 0 db, they would still differ at any other setting including -15 db. Different rooms, speaker efficiencies, amp gain, etc.
  • sda2mike
    sda2mike Posts: 3,131
    edited October 2011
    normally, i listen at 9 o clock on the dial...sometimes 930 is fun...just got done listening for an hour @ 10! sounds so fkn good, you gotta remind yourself it's pretty loud! my ears feel almost like getting out of a concert..it really is a 'right there' experience...good to know the only thing holding me back, is me;)
    F1nut Posts: 50,504
    edited October 2011
    Can't do that on my 2 channel rigs.
  • falconcry72
    falconcry72 Posts: 3,580
    edited October 2011
    yep.
    mid 80's to low 90db's for me, when I'm really listening.
  • quadzilla
    quadzilla Posts: 1,543
    edited October 2011
    Loud, effin' loud, or a level that makes me yell "WHAT DID YOU SAY?" at everyone for 3 days after a session.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: Aural Thrills
    Digital: Pioneer DV-79ai
    Pre: Conrad Johnson ET3 SE
    Amp: Conrad Johnson Evolution 2000
  • TECHNOKID
    TECHNOKID Posts: 4,298
    edited October 2011
    Joe08867 wrote: »
    Same here, when I'm in the mood however, the rule is never above 1/2 otherwise its time to replace the amp! :wink:
    BlueFox wrote: »
    During serious music listening I don't care for conversation. Back ground music is ok during social gathering but I tend to avoid as it often gets me in trouble (tend to focus on the music ratter than conversation). Sure, go db rating, very fancy and cool tecky talk but means d***k unless we are all using same amp, same room environment and we all have equal hearing. I still wonder how accurate the db rating is on the dial (of most gear) anyway...
    DARE TO SOAR:
    “Your attitude, almost always determine your altitude in life” ;)
  • falconcry72
    edited October 2011
    TECHNOKID wrote: »
    ...Sure, go db rating, very fancy and cool tecky talk but means d***k unless we are all using same amp, same room environment and we all have equal hearing. I still wonder how accurate the db rating is on the dial (of most gear) anyway...
    Huh? I think most of us who cited db levels were referring to measured levels with an SPL meter.:wink:
    Oh, and you put too many letters in "dick". :razz:
  • BlueFox
    edited October 2011
    Exactly. 70db is 70db irrespective of the room, the amp, whatever. Also, unless you are a hermit, at some point you will be asked a question and need to answer. If you are in to 80, 90, 100+ db range you will either have to turn the music down, or shout. WHAT DID YOU SAY DEAR? TURN THE MUSIC DOWN A$$HOLE. :wink:
    The db number on a dial means nothing. Some even go to 11.
    Apparently some people know d!(k about sound.
  • ptrooper
    ptrooper Posts: 501
    edited October 2011
    spl level around 65 to 70 db peaks are comfortable for me and my partner toenjoy and relax in!
  • kuntasensei
    edited October 2011
    WilliamM2 wrote: »
    No... that's the whole point of calibrating relative volume so that 0 = 105dB. You're calibrating around the room, speaker efficiencies, amp gain, etc. so that when you turn the volume down -15dB from that reference, it's a linear control.
    Regardless, I just realized we were talking about music here, which makes this question kinda' hard to answer... considering all you can really say is "loud" unless you're actually pulling a SPL meter out and taking an average.
    Equipment list:
    Emotiva XPA-3 amp
  • IRLRaceFan
    IRLRaceFan Posts: 172
    edited October 2011
    Most of the time I listen at slightly higher than moderate levels.
    But when drinking and ping pong is involved, the volume level is proportionate to the number of beers consumed :cheesygrin:
    Some music is just meant to be played LOUD
    HT
    Onkyo TX-NR1008 | Magnepan 1.7 | Polk LSiC | Polk VM20 | Polk DSW microPro 2000 | Parasound HCA-2205A | Oppo BDP-93
    2-Ch
    Cary SLP 30 Tube Preamp | Polk LSi7 | Carver M1.5t | Audio-gd Digital Interface | W4S DAC-2 | MAC Mini | Denon DP300f & Pro-Ject Debut III TT's
  • kn505
    kn505 Posts: 380
    edited October 2011
    1/4 to 1/3 most of the time. I tend to turn it louder when I am exercising.
  • BlueFox
    edited October 2011
    As a personal example of how the volume setting really means nothing in regard to the sound level, when I first bought my current two channel system I only had one amp. In stereo mode it makes 350w/channel @ 4 ohm. With this I used to keep the pre-amp around -25db to produce the sound level (70db range) I use for classical music. Later, I bought another amp, and put both into bridged mono mode. In this configuration, each one is rated at 800w/ch at 4 ohm. Now, the pre-amp is set at -45db to produce the same SPL levels as before.
  • inspiredsports
    inspiredsports Posts: 5,501
    edited October 2011
    thsmith wrote: »
    Perfect!
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
    gudnoyez Posts: 8,114
    edited October 2011
    It depends on the mood for laid back listening on the upstairs system -15dbs will do me fine those Polk's sound pretty sweet at that level, when it comes to the down stairs systems, that's when its time to get LOUD I usually turn the dial to around 10 or 11 o clock, and put those Acoustic Research's to work more than that, and the towns finest would show up at the door, so be it. I must restrain myself to 11 o clock.
