L/R surrounds with RTi A3's
I just ordered a pair of Rti A3's to use as left and right and a csi A4 for center for my home theater. I am upgrading from an Energy Take Classic 5.1 system. My question is, will the energy L/R surrounds suffice until I am able to get bigger surrounds to match the RTi A3's? And, what rear surrounds would you guys recommend to compliment the A'3's?
Post edited by njs2247 on
Fxi A4's or 6's would be what I would shoot for. The are great surround speakers. The shape and sound coming out of both sides make them harder to pinpoint the speaker. They are worth the added cost over running another set of a1's or 3's.AVR: Onkyo Tx-NR808
Rear: FXI A4
Sub: Polk DSW Pro 660wi
TV: LG Infinia 50PX950 3D
IC: AudioQuest Black Mamba II -
The short answer is YES, almost any reasonably accurate speaker will suffice until you are able to up-grade. Best of luck.Main Family Room: Sony 46 LCD, Sony Blue Ray, Sony DVD/VCR combo,Onkyo TXNR 708, Parasound 5250,
Living Room: Belkin PF60, Parasound HCA2200, MIT ProlineEXP balanced IC's,Emotiva XDA-1 DAC/Pre,Emotiva ERC2 transport,MIT AVT2, Polk LSI 9's. -
Just move your current speakers to the back and balance everything out. RTI's sound great. The rears I use are cheap and are not voiced matched to my RTI's but untill I get the funds, I'll use what I have.
When I get the surrounds in my system they will most likely be monitor 30's. They are inexpensive and will be fine for surrounds. -
I would (and did) make the A3's the rears and buy A5's for the fronts. Add a good sub and your done! Good luck with your decision.
PatYamaha RX-A700
Polk Audio RTi A5
Polk Audio CSi A6
Polk Audio RTi A3
Polk Audio DSW Pro 500wi -
That would be my choice if I was going to run regular book shelf surrounds. Get A5's for the front and move your current speakers to the rear.AVR: Onkyo Tx-NR808
Rear: FXI A4
