Brand New Lamp Assembly InFocus SP7210
seeclear
seeclear Posts: 1,244
edited October 2011 in For Sale (FS) Classifieds
We had a SP7210 humming away in the home theater, but in July got a lightning strike near the house and it got zapped. I have a brand new in the box bulb/lamp assembly that I had gotten as a backup that I would like to sell for $200 shipped in the CONUS. It is sealed in the box.
Here's a bonus if you want it--there is a bulb in the projector, I'm not sure how many hours are on it and obviously it won't turn on so I can look, but figure around 1000. I can send that along to the buyer as well for an additional $0. I wouldn't trust me to remove it without busting it up,tho. If you want the projector, too, to see if you can fix it, I'll split shipping on that with you, too. I looked up shipping for a potential buyer in NC and it would be ~$30 in the original box; if you'd like it double boxed add another $10 for the box and additional shipping. So, $15-20 to get the fixer upper projector too. The 7210 is a 720p DLP projector. Specs below.
Here's what it did after the lightning strike--when plugged in it would make a quiet noise like the fan was trying to start, but it would not do anything else, either with the buttons on the unit or with the remote. I figure it probably is a fried PCB inside, but I never had it checked out or sent to infocus for service or an estimate, so that is purely speculation on my part. PM me with questions or interest.
Native Aspect Ratio: 16x9
Supported Aspect Ratio: 4:3, 16:9
Brightness: (max ANSI lumens) High Bright: 1100 Lumens
Eco Mode: 950 Lumens
Contrast Ratio: 2800 : 1 Full On/Full Off
Display Technology: 720p+ DarkChip3 DMD DLP by Texas Instruments
Data Compatibility: VGA (640x480), SVGA (800x600), XGA (1024x768), SXGA (1280x1024), 720p (1280x720)
Video Compatibility: Full NTSC, PAL, SECAM, 480i, 480p, 576i, 576p, 720p, 1035i, 1080i, 1080p/24, 1080p/30
Color Wheel (DLP Only): 7-segment, 4x
Native Resolution: 1280x720
Projector Placement: Ceiling Projection, Rear Projection, Front Projection
SMPTE Brightness: Up to 132"/3.35m wide, 16:9 screen
Lamp Wattage: High Bright: 250 Watts
Eco Mode: 220 Watts
Lamp Life: High Bright: 2000 Hours
Eco Mode: 3000 Hours
Minimum Image Size: 2.8 ft (0.85 m)
Maximum Image Size: 17.6 ft (5.36 m)
Standard Lens Zoom: 1.3 : 1
Standard Lens Throw Ratio: 1.67 - 2.08:1 (Distance/Width)
Standard Lens Image Offset Ratio: 116% (16:9)
Standard Lens Projection Distance: 5 - 32 ft (1.52 - 9.75 m)
Digital Keystone Correction (Vertical): +/- 20?
Digital Keystone Correction (Horizontal): +/- 9?
Lens Shift: Not Available
Inputs and Outputs
USB: Not Available
DVI: Number of Inputs: 1
Requires M1 to DVI cable
M1: Number of Inputs: 1
Accepts VGA and DVI with M1 cable
HDMI: Number of Inputs: 1
Requires M1 to HDMI adapter
BNC: Not Available
Component (RCA): Number of Inputs: 2
Gold RCA
VESA (HD15): Number of Inputs: 1
15-pin analog
S-Video: Number of Inputs: 2
4-pin DIN, no progressive support
Composite (RCA): Number of Inputs: 1
Standard Definition TV: Composite RCA, S-Video, Component RCA, D5
Enhanced Definition TV: Component RCA, M1-DA, VGA, D5
High Definition TV: Component RCA, M1-DA, VGA, D5
Computer: M1-DA, VGA
HDCP Support: Yes
Stereo RCA Jacks Inputs: No
Stereo 3.5 mm Mini-jack Inputs: No
12v trigger for motorized screens (3.5 mm mini-jack): Yes
Projector Control: Remote, Projector Keypad, RS-232
Speakers: Not Available
Monitor Output: No
Audio Output: Not Available
Compatibility
H-Sync Range: 21 - 91kHz
V-Sync Range: 50 - 85Hz
General
Audible Noise: Not Available
Actual Dimensions: Height: 4.3 in (10.92 cm)
Length: 12.8 in (32.51 cm)
Width: 13.8 in (35.05 cm)
Actual Weight: 9.5 lbs (4.31 kg)
Shipping Dimensions: Not Available
Shipping Weight: Not Available
Projector Warranty: 2 years
Lamp Warranty: 90 days
Accessories Warranty: 90 days
Operating temperature:
(at sea level) 50 - 104? F (10 - 40? C)
Maximum Altitude Supported: 10000 ft (3048 m)
Typical Power Consumption: 220 Watts
Maximum Power Consumption: 250 Watts
Power Supply: 100 - 240 Volts at 50 - 60 Hz
Menu Languages: French, English, Italian, German, Korean, Japanese, Portuguese, Spanish, Traditional Chinese, Simplified Chinese, Norwegian, Russian
Approvals: UL, c-Ul,TUV GS, GOST, C-Tick, NOM, IRAM, FCC B, CISPR22/EN55022, EN 55024/CISPR 24, CB certified according to IEC60950/EN60950; 1997, P(SE), MIC
"Don't forget to change your politician. They are like diapers they need to be changed regularly, and for the same reason."
Post edited by seeclear on
