Rebuilding Crossovers
mlhm5
mlhm5 Posts: 217
edited October 2011 in Vintage Speakers
Who does this ?
Post edited by mlhm5 on
  • quadzilla
    quadzilla Posts: 1,543
    edited October 2011
    A lot of people do their own but there's also a few guys that will do it for you. Im thinking about becoming one of those guys.
    Turntable: Empire 208
    Arm: Rega 300
    Cart: Shelter 501 III
    Phono Pre: dsachs consulting
    Digital: Marantz SACD 30n
    Pre: Conrad Johnson ET3 SE
  • Schurkey
    Schurkey Posts: 2,104
    edited October 2011
    Did my own. Simple, with instructions and advice from this forum.
    Do one at a time, when the first is finished, install it and listen. If it sounds OK, use it as the guide for doing the second one.
    That way you're sure to solder the leads into the correct holes.
  • Face
    Face Posts: 14,340
    edited October 2011
    Which speakers, what do you need done?
  • mlhm5
    mlhm5 Posts: 217
    edited October 2011
    Face wrote: »
    My 7c's have never had anything done to them. They have the Peerless and am wondering if they would sound better with an upgrade.
  • quadzilla
    edited October 2011
    Yes.. yes they would.
    Arm: Rega 300
  • acerjac
    acerjac Posts: 28
    edited October 2011
    Give it a shot. I have the SDA 2's, RTA 15's, RTA 8tl's, Monitor 5B's, and the Monitor 4A's. I have modded all of them except the 4's. I was very nervous when I started, but with help from this site and taking my time, it worked out very well. Its allot of fun also. Don't be afraid to give it a try.
  • DON73
    DON73 Posts: 516
    edited October 2011
    mlhm5 wrote: »
    I had my 7s done by a member on CP. I also sealed the drivers with Mortite. There was an improvement in all ranges but mostly the upper mid and high range. I have another pair of 7s that I will probably do myself when I get around to it. The crossovers are easily removed and if you can solder it should be easy for you to do.
    The person that did the work on my crossovers does outstanding!! work on everything he does. PM me and I'll give you his name.
    TO ERR IS HUMAN. TO FORGIVE IS CANINE.
