SDA trouble shooting - where to go next?
quadzilla
quadzilla Posts: 1,543
edited October 2011 in Vintage Speakers
I'm still loving my 2.3 TLs, but even when I first hooked them up, I noticed that the SDA effect in the left channel didn't seem as strong as in the right. After a few days of close listening, and judicious use of the channel inverter switch on my pre, I'm certain that it isn't. I've verified the following:
Alignment - speakers were aligned to the same plane using a laser sight, and to the same distance from the back wall and side walls.
Mono signal - balance to left results in right dimensional drivers on, left stereo drivers muted.
Mono signal - balance to right results in left dimensional drivers on, left stereo drivers muted.
Battery test - all drivers move in unison on both speakers.
Verified amp - used my backup common ground amp, same issue.
Verified pre to amp ICs - tried a spare set, same issue.
Verified source to pre ICs - tried a spare set, same issue.
What's interesting is that if I flip the phase (by reversing the speaker cable) at the amp on the left channel, I get a strong SDA effect, the same as the right channel, but the image is pulled hard to the left. Flipping both channels just results in the original issue.
The rest of the set up is: CJ pre, tube mono blocks, AI-1 SDA IC.
From reading the SDA trouble shooting guide, it seems like most SDA issues are related to phase. And the fact that if I flip the phase on the speaker cable to the left channel gets a strong SDA effect, I think it is a phase problem. But I can't figure out where to look next. Or does the fact that even though all the drivers in the left channel move together when testing with a battery still allow for the possibility that the SDA drivers in one or both channelse are out of phase?
TIA
Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Post edited by quadzilla on
    F1nut Posts: 51,700
    edited October 2011
    That isn't right.
    It should be as follows;
    Mono signal - balance to left results in left channel stereo drivers on, right channel dimensional drivers muted.
    Mono signal - balance to right results in right channel stereo drivers on, left channel dimensional drivers muted.
  • Schurkey
    Schurkey Posts: 2,122
    edited October 2011
    quadzilla wrote: »
    That's got to be part of the problem. I'd expect with a mono signal, the balance to the left, the left stereo drivers should not be muted.
    quadzilla wrote: »
    That's good.
    quadzilla wrote: »
    Verified amp - used my backup common ground amp, same issue...
    ...The rest of the set up is: CJ pre, tube mono blocks, AI-1 SDA IC.
    What happens with the common-ground amp and a regular SDA interconnect cable?
    Is that a home-made AI-1?
  • george daniel
    george daniel Posts: 12,096
    edited October 2011
    ^^^^ common ground amp and sda cable^^^^^^^^^---good point.
    Please let us know what you find.
  • quadzilla
    edited October 2011
    Schurkey wrote: »
    Crap, I wrote that backwards. It should be:
    Mono signal - balance to left results in right dimensional drivers on, right stereo drivers muted.
    Sorry for that eff up.
    It's a Polk AI-1. I haven't tried a standard SDA cable and common ground amp yet.
    Arm: Rega 300
  • george daniel
    edited October 2011
    just a thought,,but does the CJ invert phase?
    Toolfan66 Posts: 17,998
    edited October 2011
    quadzilla wrote: »
    I just did the same test and that's how mine are as well.
    Mono, balance to the right stereo is to the right on the left dimensional drivers on stereo drivers muted.
    Mono, balance to the left stereo is to the left on the right dimensional drivers on stereo drivers muted.
  • quadzilla
    edited October 2011
    Well... common ground amp and standard SDA cable works fine. Uhm... AI-1 wired out of phase?
    Arm: Rega 300
  • quadzilla
    edited October 2011
    Not according to http://www.conradjohnson.com/It_just_sounds_right/a-PV2.html
    Phase Response: Line Stage phase correct, Phono Stage phase correct
    I opened the AI-1. Could someone with a known good cable check against this pic? I'm assuming the transformer doesn't phase invert? If so, then the AI-1 is definitely out of phase. But what I don't understand would be why when I reversed it, the problem didn't switch to the other side.
    AI-1.jpg 128.6K
    Arm: Rega 300
    F1nut Posts: 51,700
    edited October 2011
    quadzilla wrote: »
    Possible. It's also possible that the connections on the back of the binding post are wired incorrectly.
    If you remove the top of the AI-1, you should see the black and white wires reversed on the other side of the transformer.
  • quadzilla
    edited October 2011
    OK, well, that answers the question I just asked.... I checked the wiring on the cups. It's the same on both sides. I didn't pull the passives to check the crossover though. Guess that'll be next.
    Arm: Rega 300
    edited October 2011
    So do I have the same issues?? My speakers sound great and the front stage is wide and deep.
  • quadzilla
    edited October 2011
    Unless one of your channels sounds like it never expands past one of the speakers, probably not. That's the effect I have. The right side extends at least to the wall. The left channnel seems stuck to the speaker.
    Also, now I'm more confused. I strapped the grounds together on the monoblocks and ran the standard SDA cable. I had no SDA effect at all at the point from either channel.
    Arm: Rega 300
    edited October 2011
    My speakers are working as they should and are wired correctly.. quadzilla you had me second guessing things LOL!!!
    I have some media that sounds stronger on the right channel now and then and I have to say it f#@k's with me sometimes..
  • quadzilla
    edited October 2011
    Well, thought I'd found it.... not so much. Seemed to work for a minute, but either it came back or I was just fooling myself.
    Arm: Rega 300
    edited October 2011
    Awesome!!!! you should build a Dreadnaught!!! ;-0
  • OldmanSRS
    OldmanSRS Posts: 419
    edited October 2011
    quadzilla wrote: »
    This will be the norm if your speakers are wired correctly but you have them physically reversed L to R.
    '65 427 Shelby Cobra
    '72 Triumph TR-6
    __________________
    '88 Polk SDA SRS 1.2, with upgraded XO caps and Erse SDA inductors
    '86 Polk SDA CRS+
    '84 Polk Monitor 10A (Peerless tweeters)
    '05 HSU VTF-3 Sub (Original OEM)
    '20 HSU VTF-3 Sub (three more, 100% cloned)
    '93 Carver TFM-35
    '88 Carver M-1.0t
    '88 Adcom GFT-555
    '88 Adcom GFP-555
    '88 Adcom GFA-555 (upgraded/restored)
    '88 Adcom GFA-555 (a second one upgraded/restored)
    '05 Onkyo DV-555 media
    '89 Fosgate 360 Digital Space Matrix
    '89 Fosgate 360 Digital Space Matrix, internal surround amp bridged to drive only a center channel
    '91 Kenwood Basic M1D Amp
    '89 Pioneer Laser Disc media
    '89 Sony SuperBeta HiFi media
    One PGA2310 based custom built remote volume control
    Four Polk T-15's
    Four Polk TSi-200's
    Four Polk TSi-100's
    Two Polk CS-10's
  • quadzilla
    edited October 2011
    OldmanSRS wrote: »
    No, that's correct. With a mono signal and full left balance, the right stereo drivers should be muted and the right dimensional drivers should activate according to the SDA trouble shooting guide.
    Arm: Rega 300
    F1nut Posts: 51,700
    edited October 2011
    For the record, my post in #2 is wrong. I was thinking stereo instead of mono.....sorry for the confusion.
  • quadzilla
    edited October 2011
    For what it's worth, this turned out to be a couple of things. One is that the AI-1 cable is twitchy. I sort of resolved that by running a coat hanger from the bass bolt down and making a hook to take the strain off the connector. The other is that the end caps were actually pretty off, so when I aligned the speakers, the right was toed out and the left was toed in by a fair bit. But at least it's working now. And I have to tighten the end caps...
    Arm: Rega 300
  • Schurkey
    edited October 2011
    quadzilla wrote: »
    the ai-1 cable is twitchy.
    Dreadnaught!
