Banana Plugs and my first impression of the A4
tommyt21
tommyt21 Posts: 685
edited September 2011 in Speakers
Hello Polkies,
:sad:I feel stupid for asking this but how to you remove the plug in the center of the speaker terminals to use the banana plugs?
I just got the Csi A4 yesterday and I have to say the clarity on it was so much better than my CS10. I thought the CS10 was good but after putting the A4 up i noticed better in your face imaging and less boxy-ness than the CS10. It made it hard to tell that my T90e's were even playing. When I hook it up to my SC-35 I imagine the sound will be even better! Rti A7's will be here on monday then its off to the races.
Living Room
Fronts: RTi A7's
Center: Csi A6 VR3 "Fortress Plus"
Front Heights: Rti A1
Surrounds: Rti A3
Sub: HSU VTF-2 MK4 Damn this is a good SUB
Pioneer Pioneer Elite: SC-35-> Emotiva XPA-3
TV: Lg LW6500 55" Passive 3D
Blu-Ray Panasonic BD 210
XboX 360 Slim/Kinect
Acoustimac red suede panels
Post edited by tommyt21 on
  • cubdog
    cubdog Posts: 835
    Assuming your Polk teminals are the similar to my Klipsch's just take a small screwdriver or something similar and pop them right out.
    cubdog
    Shuguang Classic S8MK
    Emotiva XDA-2
    Bel Canto M300 mono blocks
    Bel Canto DAC 1.5
    Squeezebox Touch
    Sony SS-M7
    A/D/S L710
  • Drenis
    Drenis Posts: 2,871
    I just unscrewed mine all the way, carefully turned them upside down and tapped them lightly on a hard surface and they came right out... screwed the terminal back onto the post.
    Repeat steps 1-2.
  • decal
    decal Posts: 3,205
    PM polkfarmboy and ask him the step by step procedure!!!!:cheesygrin:
  • jbooker82
    jbooker82 Posts: 1,627
    :lol:
    decal wrote: »
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • leadfoot1
    leadfoot1 Posts: 155
    Just unscrew the speaker terminal until it comes off. Then pop off the red and black caps (you might need a small screwdriver). Then screw the terminal back on and plug in your banana plugs. :wink:
    nooshinjohn Posts: 25,932
    decal wrote: »
    LOL!:biggrin:
    I was thinking the same thing. It takes a village.:wink:
  • tommyt21
    tommyt21 Posts: 685
    LOL!:biggrin:
    :sad: See I knew it was a stupid question, However when I tried unscrewing them they got really tight and I just wanted to make sure just incase I was going to break them
    Living Room
    Fronts: RTi A7's
    Surrounds: Rti A3
  • jbooker82
    tommyt21 wrote: »
    Nothing directed twards you. It was an inside joke. Polkfarmboy broke some binding posts off his emotiva amp. He then started posting about emotiva's bad customer service, and product quality. Most people didn't see it his way and gave him crap about using so much foce to break them off.
    just unscrew them all the way and use a screw driver to pop the center plugs out. Mine came out just by unscrewing the nuts.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • danger boy
    danger boy Posts: 15,722
    i used a drill with a small drill bit and demolished them... works great. :lol:
    PolkFest 2012, who's going>?
