New sub advice needed..
BigA524
BigA524 Posts: 63
edited October 2011 in Speakers
My system is below. I was using the Sony SA-WX700 as my sub. dual 10s in them. I thought it matched pretty good with what I had. Looking for something similar and if possible under $500. What goes well with the RTis? I do both movies and music.
thanks
Marantz 1607 - Polk S60 - S35 - Emotiva XPA-3 - Polk DSWPRO550wi
Post edited by BigA524 on
  • BigA524
    BigA524 Posts: 63
    edited September 2011
    Room is 20x20.
    Any thoughts on the Polk Audio DSWPRO 660wi 12-inch Wireless Ready Subwoofer
  • jbooker82
    jbooker82 Posts: 1,627
    Awesom sub. I like mine alot and would recomend one. The nice thing about the WI's are double the wattage of the regular DSW Pro line.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • DarbyPope
    DarbyPope Posts: 3
    My experience is that subs are different things to different people. Also, the size of the room and the need (audio/video) add into what you might need.
    Watts don't mean too much if there are enough. Actually, the build and especially on the lower end, bigger size is better.
    Some good, large older Polks can be found under $500 on ebay that are excellent, especially for video.
    I surely don't need another sub, but the one that intrigues me is the EPIC EMPIRE. It is big, cheap, and gets good reviews.
    If I were buying on the cheap - would try that.
  • nhhiep
    nhhiep Posts: 877
    for under 500. get yourself 2 PSW505 or BIC F12 for $200 each.
  • jbooker82
    nhhiep wrote: »
    DSW Pro 660WI plays lower than the BIC F12 and the DSW PRO and DSW PRO WI's are way better than the PSW505's
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
  • nhhiep
    nhhiep Posts: 877
    jbooker82 wrote: »
    of course, The 660wi costs double. I am just pointing out what $200 can do.
  • Theheadsn
    Theheadsn Posts: 413
    DarbyPope wrote: »
    Great point. Ive been wanting an Epik for some time.
    Check out the website http://www.epiksubwoofers.com/products.html
    And check out this cool tests they did with the Epik and other subs, it might give you some ideas. It won me over haha http://www.avsforum.com/avs-vb/showthread.php?t=1313176
    Home Theater Setup
    • Receiver - Onkyo TX-RZ1100
    • Mains - Polk RTi A9's
    • External Amps - Outlaw 2200 Monoblocks for L/R/C
    • Center - Polk CSiA6
    • Side Surrounds - Polk FXiA6's
    • Atmos - 4 Polk 80F/X RT's
    • Sub - SVS PC-4000
    • T.V. - LG OLED65C7P
  • BigA524
    BigA524 Posts: 63
    edited October 2011
    Can anybody what would be the dif between the psw110 and the DSW PRO 550wi? Sound wise. Is it worth it spending the extra for the dsw?
