Speaker stands
Wondering which material makes for a better speaker stand (if there is a difference)...steel or wood?
Post edited by mknutt on
Hey MKNutt, Just got done with the speaker stand thing , when I purchased my LSi's. What I have found...you have heard location , location, location....I have found the key is weight , weight, weight. Metal, would be and is my stand of choice. Tried a couple of the more inexpensive stands, Sanus and the like, they couldn't comfortably handle the weight. Ended up with Plateau series V. They are as heavy as the speaker itself, no movement or vibrations of the stand or the speaker...feels like the 9's are glued to the thing. But of course with the weight comes $$$$. $179 for the Plateaus. Even with my JBL's upstairs I have lighter stands and they seem to blow themselves off the lighter stands from time to time....
StuffYour system is only as good as your weakest component...!
OnkyoTX-DS 797
NAD C270/ Mains
Mains: LSI9's
Center: Cs400i /Biwired
Rear: Fx300i
Rear Center:CS 245i
Dvd: Onkyo DVS 555
Vision RCA 36" Premiere Series
Bang & Olfsen RX Turntable
Psw 350 Front/Psw 202 rear
Kimber Cable 4TC Mains HF
Monster Originals/Center
Kimber Interconnects
Monster XP Everywhere else
PS2/Gamecube -
I built my own stands, have a look HERE they are based on this design
My stands are VERY solid and I built them for about 80 bucks. not too bad. filled with sand they weigh about 50 to 60 pounds. I saved myself about $200 from the stands I "wanted" to buy. my DIY stands do the job and do it well. some day I may get some "better" stands but not any time soon...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15
