Help!!! I am stuck in the MOBILE theme
BlueFox
At the bottom of the 'regular' forum page there is a theme dropdown with three options. Default (fugly blue), Red/Gray, and Mobile. I tried Mobile and want to go back to Red/Gray, but the theme option is missing from the Mobile theme page. Aaaaargh!!!!
Post edited by BlueFox on
Keep hitting the back button.
There should be a link that says full version or something along those lines at the bottom of the mobile page.
Once you're in the mobile view it is no longer on the bottom. It's to the right of the VBulletin header with the 9 dots in a blue square. Click on that and you can change it at the bottom where it says 'Full Site'.
Thanks all. In the Mobile version none of the replies showed up as new posts, so I did not see any of them. I found another way. I logged out and logged back in. So much for that theme. :eek:Lumin X1 file player, Westminster Labs interconnect cable
Three 20 amp circuits. -
HAHAHA!!! Just happened to me also. I was able to just click on full site and get it going again. This is SPARTA!!!!Shoot the jumper.....................BALLIN.............!!!!!
