How difficult is it to put a cable line into my room?
kazaam
kazaam Posts: 92
edited September 2011 in The Clubhouse
Is it pretty easy or should I just pay my cable provider the $32 to do it?
Post edited by kazaam on
  • Joe08867
    Joe08867 Posts: 3,919
    It depends on the room. $32.00 is pretty cheap so I am guessing he just runs a line through the floor or a wall and connects to the box. I doubt you will get a faceplate installed for that cheap.
    I did all the cable runs in my home.
  • bruss
    bruss Posts: 1,039
    go measure how many ft of cable you would need and see how much you would save by doing it.. 32 bucks is pretty cheap
  • BlueFox
    BlueFox Posts: 15,251
    Can you cut coax, crimp connectors, test for shorts?
  • jbooker82
    jbooker82 Posts: 1,627
    Well the reason why it is cheap is because of how they run it. Most cable companies or satellite installers just run it on the out side of the house then drill a hole clear through the wall. It is a half a$$ job. I would be really mad if they ran it that way in my house. Nothing like punching holes through the exterior walls instead or fishing it inside.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • unc2701
    unc2701 Posts: 3,587
    jbooker82 wrote: »
    Agree completely. They put a hole straight through my friend's hardwoods without even asking- total a--hole move. If it's on the first floor and you have a basement (with open joists) or a crawlspace, it's easy and takes 10 minutes. Things get incrementally harder, but with some effort and fish tape you can run wires anywhere.
    I feel like Polk had a PDF with some pointers?
    Backburner:Krell KAV-300i
  • unc2701
    Here it is:
    http://www.polkaudio.com/downloads/DIYTutorial.pdf
    Everything you need to know.
