Recommend an SPL meter please
kazaam
kazaam Posts: 92
edited September 2011 in Speakers
Low cost! :o
Post edited by kazaam on
  • jbooker82
    jbooker82 Posts: 1,627
    Radio Shack Anolog. On clearance for 14 bucks if you can find one.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
  • Esreuter
    Esreuter Posts: 176
    +1
    On what jbooker said.
    I have the rat shack analog meter, runs on a 9v battery and is fun to use.
    you will notice a difference once you dial everything in.
    Have fun with it!
    ESR:cool
    AVR: Sony 5600ES
    Center: CS2II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Front: Monitor 70 II (Clarity Caps PX, Perfect Lay coils, Mundorf resistors)
    Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    Rear Surrounds: Monitor 40 II (Clarity Caps PX, Perfect Lay coil, Mundorf resistors)
    More to come :biggrin:
  • cristo
    cristo Posts: 231
    +2 for the old style analog radio shack spl meter.
    The older style has a little increased response in the 2KHz to 10KHz range and rolls off fairly
    steeply in the last octave (10K-20K).
    The newer style analog meter has a bit more peak in 3K-8K and even more roll off above 10K
    than the older ones.
    The new digital style has a big peak in response from 4K to 10K, but is more accurate from 10K-20K,
    and also has a lot more roll off in bass frequencies in the bottom two octaves than the analog ones.
    Here's a link to a review of the older and newer analog meters and the newer digital one.
    It will give you a good idea of the accuracy of the meters relative to frequency in particular.
    http://www.audioxpress.com/magsdirx/ax/addenda/media/koya2811.pdf
    cristo
    NAD C 545BEE cd player, Philips AF877 turntable / Shure V15V-MR with JICO SAS stylus,
    Tascam 122 mkIII cassette deck, Harman Kardon 3480 receiver, Terk FM-50 antenna in the attic,
    Soundcraftsmen SE550 stereo equalizer, Polk Monitor 10a speakers
    (with Sonicraft/Solen/Mills crossover rebuild)
  • djperez81
    djperez81 Posts: 388
    I also have the analog SPL meter from Radio Shack from 15 bucks you cant beat it. Good luck trying to find one since they have been on clearance for a while now.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
