Home made subwoofer is done!
Well, my forum friends, my 1'st home made subwoofer is done! Special thanks to Burdette, Madmax, Tryrrthg & jcaut for all their help a couple of weeks ago with this project.
Now, some background info on the project. I had 2 JL Audio 12W-1 subs lying around. I then designed a ported box using WinISD. The box is 3 cubic feet, tuned to 31 Hz. The cabinet is constructed from 3/4" MDF. The cabinet is finished with black ash vinyl laminate from Parts Express. It is lined with convoluted acoustical tile, also from PE. The cabinet feet are the Dayton Audio speaker cones, (the large ones) from PE. The box was glued together with carpenters glue & clamped, then screwed together with 2" drywall screws.
The only thing missing now is the amp. I will be getting the 180 watt RMS plate amp from, you guessed it, Parts Express. In the one picture, you can see the inside of the box. The hole you are looking thru is where the amp will be mounted.
Also, the room these pics was taken in is NOT the room my system is set up in, it is just an extra bedroom/storage closet. My family room is currently being renovated, and my system has been shelved for the time being. But, my beloved R30's are still hooked up, so I can enjoy them, albeit in a 7 foot wide room.
Let me know what you think. I'll post again when I get the amp installed to let everyone know how it sounds.
Greg
Greg
Bob Mayo, on the keyboards. Bob Mayo.
my attachment did not load, i'll try again. it was too big.Bob Mayo, on the keyboards. Bob Mayo.
That looks real good G, nice job. I like the acoustic foam inside the box. Can't wait to hear about how it sounds.CTC BBQ Amplifier, Sonic Frontiers Line3 Pre-Amplifier and Wadia 581 SACD player. Speakers? Always changing but for now, Mission Argonauts I picked up for $50 bucks, mint.
Nice work!
Keep us in the loop.
Cheers,
can someone post the pic, i can't seem to download it, it comes up in my gozilla as .php file what ever that is...MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
by the way,
How do you post pics? I would have done it myself but I don't know how.Bob Mayo, on the keyboards. Bob Mayo. -
Quit EFFIN WITH IT!!!! WAAAAAAAAAAAAAAAAAAAAAAACheck your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
here ya go. if attaching from your computer hit the attach file button under the reply box. if they're on the web hit th IMG box just above the reply box...
EDIT: pics deleted, russ beat me to it...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
Pic 2...Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Another....Check your lips at the door woman. Shake your hips like battleships. Yeah, all the white girls trip when I sing at Sunday service.
Nice job on the sub!
I REALLY wish I could try this sometime but I don't have the extra cash to try it... Don't have room in my tiny little apartment either... The PSW450 takes up too much room as it is, let alone a 250 liter Stryke AV15 sub...Sony KDL-40V2500 HDTV, Rotel RSX-1067 Receiver, Sony BDP-S550 Blu-ray, Slim Devices Squeezebox, Polk RTi6, CSi3 & R15, DIY sub with Atlas 15 -
nice job on the veneer, looks goodMY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
One unfair advantage I forgot to mention... I had all the detailed areas of the blanks cut on a CNC machining center. The driver baffle holes, the port tube hole, the internal brace, the square hole for the amp, & the internal channels that the internal braces sits in.
I am lucky enough to work at a place with a machine shop. The CNC operator had all the pieces cut in about 1 hour, all PERFECT. Assembly went without a hitch.Bob Mayo, on the keyboards. Bob Mayo. -
Great work, really sharp. Let us know how it sounds over time.
Doc"What we do in life echoes in eternity"
SVS -
