Bada HD-22 cdp
edoggrc51
Hey fellas selling a very nice Bada HD-22 TUBE cd player. The player is in fantastic condition and sounds awesome! Here's some specs on it. Will Post pictures later tonight.
Price: $300 including PayPal & Shipping
From Bada, a vacuum tube HDCD vacuum
tube CD Player with the sound of CD players
costing 3 times as much. The Player uses
Burr Brown 's latest PCM1732 HDCD D/A chip
set. The Bada H22 provides two sets of
outputs: solid state and vacuum tube.
The player uses the great sounding 6N3 tube
that can also be found in the Shanling T-100
of which its design is based. The 6N3 tube
is a dual triode and in one working tube can
be found two working tubes: one for each
channel. The tube is used as cathode
follower from the BURR BROWN OPA2134
OPAMPS and since the circuit uses both
sides of the 6N3, only one tube is necessary.
( this is the same configuration that all the
Lite DACs follow).
The result is superior tube based HDCD
sound from a reasonably priced CD player.
You can also compare this circuit
configuration to the AH! TJOEB that uses
6922 tubes in a cathode configuration and
projects the "grain" so common from low end
6922 tubes. BADA gives you one great tube,
the 6N3 with its clear holographic image
without the grain.
Specifications:,
Philips Laserhead and Transport
BurrBrown PCM1732 HDCD D/A Chipset
6N3 / 5670 Tube
96KHz/24Bit Digital Output
HDCD Filter Optimized For 44.1KHz To
96KHz
Tube and solid state Output
Two quality Transformer s for Digital and
Analogue
High Quality Op Amplifier - BB OPA260
Output Power: <=2.2V
Frequency Response: 20Hz~20kHz(?0.
5dB)
S/N Ratio: >=110dB
THD: <=0.005%
Dynamic Range: 110dB
Channel Separation: 96dB
Power Input: AC 120v
Power Consumption: <=70W
Dimension (LxHxD): 43.0 x 11.0 x 37.0 cm
Net Weight: 8.0kg
Lite DACs follow).
without the grain.
Specifications:,
6N3 / 5670 Tube
96KHz
Analogue
5dB)
S/N Ratio: >=110dB
THD: <=0.005%
Net Weight: 8.0kg
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
2ch: Emotiva Stealth 8's, Airport Express
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Post edited by edoggrc51 on
interested pending pics...The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Hey John, here's some cell phone pics my wife just sent me. I'll post some better shots of it tonight. But in the mean time:
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
2ch: Emotiva Stealth 8's, Airport Express -
I've had this player (courtesy of Ricardo), left it behind in the aftermath of a divorce and I REALLY want it back... It's a stellar performer at its price point.
I'm sure this will move in no time flat, but consider me extremely interested as well.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
You got it boss. If John passes you're next in-line.Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
can't see the pics at work, but I will take a peak when I get home in a few hoursThe Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Very nice sounding player. I had this player for about a year. It beat out my NAD C-542! This is a steal at that price.
Nice looking player.... but I need one in black.. Zombie... you're next.
GLWTS.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Better pics added:
Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
I just purchased a Pro-ject Essential off the the Gon. Received it yesterday evening only to find one of the tonearm wires to be completely detached with no chance of making that repair myself. I really couldn't justify making another audio purchase at this time just hours after this. If, however, this issue begins to resolve itself immediately... I'll jump on the Bada. Move anyone below me up and I'll keep you posted.
Damn.I never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore -
Has the tube been replaced? Any skipping issues with it?Klipsch The Nines, Audioquest Thunderbird Interconnect, Innuos Zen MK3 W4S recovery, Revolution Audio Labs USB & Ethernet, Border Patrol SE-I, Audioquest Niagara 5000 & Thunder, Cullen Crossover II PC's.
As far as I remember the tube has not been replaced, though i think i have a spare one in the box. I'll verify that tonight.
I havent encontered any skipping issues. Though I will say that the player sometimes takes a little longer to load a burnt disc. No problems with original CD's though.Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
nooshinjohn wrote: »Nice looking player.... but I need one in black.. Zombie... you're next.
GLWTS.
just an FYI I've never seen this in black nor is their any option from the sites I see to purchase it in black. -
I got a chance to peak inside the box last night. I did find 2 spare tubes in there. I'll include those with the sale.Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Lots of nibbles but no bites. Anyhow seriously interested let me know before I change my mind about selling it. :cool:Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
SOLD PENDING FUNDS
Thanks J!Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Thanks Eric. I've run thru quite a few CDP's in my audio travels and I always knew this one would find its way back into my rigI never had it like this where I grew up. But I send my kids here because the fact is you go to one of the best schools in the country: Rushmore. Now, for some of you it doesn't matter. You were born rich and you're going to stay rich. But here's my advice to the rest of you: Take dead aim on the rich boys. Get them in the crosshairs and take them down. Just remember, they can buy anything but they can't buy backbone. Don't let them forget it. Thank you.Herman Blume - Rushmore
No problem bro. Only Reason I sold it was to free up some rack space for monoblock #3. The Oppo's gonna have to start pulling double duty now. Anyhow, just glad it worked out for the both of us. Thanks again!Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
Congrats to both...:cool:The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
Not surprised that went fast. That was a 'fantastic' price for that player!
Enjoy!
Thanks guys! Yeah it's a really great sounding player. Only sold it to free up some rack space for monoblock #3. Looks like the Oppo will have to start pulling double duty.Denon 4311ci
MINIdsp OPEN-DRC
XPR-5
LS6 Line Arrays
LS-C Center Channel
A/V-1RS Surounds
Panny AE-8000u
2:35 110in Screen
Oppo BDP-103
Belkin PF60
Harmony ONE
