New Project: Infinity QLS1
adcomcyclone
Not sure what got in to me in the past couple of weeks, but last weekend I bought a set of SDA 2 and some RT25i (for surround), and then this weekend, I just couldn't pass up a set of parted out Infinity QLS1's. All the drivers are gone. cabinets are in solid shape, with one bubbled area in the laminate on the face, and a few nicks and dings. Looks like varnish or some other sealer was applied.
Have already acquired the necessary EMITs, mid bass couplers, several of the dome mid range, and will likely add new Watkins 12" woofers, but have to clean up the cabinets, and while I have them apart, will likely rebuild the crossovers, and maybe replace the factory wiring...it appears to be 20 or 22 guage.
The dome midranges are an interesting challenge. The tinsel connections to the voice coils were originally covered in wax to protect them, but over the years (built from 1977-1982), the wax becomes brittle, and the connections break. Found some information on how to fix online, and opened one up, seems to be simple, though probably tedious.
Any experience on here bringing vintage infinities back to life? Any pointers would be great.
Polk SDA SRS, Nakamichi Pa-5 Preamp, PA-7 Amp, Shenda (Jolida) SD100S CD Player (Sylvania Gold Brand 5751 & Amperex Holland, Orange Globe 12au7 tubes).
Home Theatre
Onkyo SR707, Samsung Blu Ray,Sony 400 Disc DVD Changer, Sony 46" LCD (Model?)
Speakers: Front L/R: JBL L7, Center: JBL LC1, Surround: TBD (likely JBL L1)
Car: Clarion 9255-DRX, Adcom GFA 4702, GFA 4404, Pioneer TS-A1702c (Front and Rear), 2 Boston Acoustics 12.5LF subs
Home Theatre
From a vintage Infinity fan, I wish you good luck on these. I hope you will keep this thread alive and post your progress; I would be very interested to see how it turns out.
G~Polk SDA SRS 2
Polk RTA 15tl
Polk Monitor 7C
Polk Lsi9
Infinity RS-II (modded)
Infinity RS-IIIa (modded)
Infinity RS 2.5 x 2
Magnepan 1.6QR (modded)
System: http://forum.audiogon.com/cgi-bin/fr.pl?vevol&1290711373 -
Geoff,
I will do my best to document my progress on them.
To date, no work done, but I have acquired all of the drivers, just waiting for them to arrive.
16 Emits (already have 8), so have some extras, just in case.
2 BRAND NEW Rear Emits
14 NOS 1.5" Dome Midranges (for the price I got these, not worth fixing broken ones!)
3 Used Philips AD5060/W8 Midbass (from B&O S60/S75), apparently the same as what was in QLS1 (1 extra)
2 New Watkins Dual Drive 12"
Now to pull out the crossovers and see if I have the brain/steady hand to rebuild them!
Will put up some pictures once I start getting stuff in and going to work on the cabinets/xovers.
Was going to put this on AK too, but for some reason, every time I log in, won't let me post.2 Channel
Home Theatre
