What are your LSi9s sitting on?
Canonshooter
I'm getting ready to pull the trigger on a set of LSi9s to replace my TSi400s in my 2-channel system. They will definitely be placed on a set of stands.
What stands/stand height are you using? I'm thinking 24" stands would look the best and be the most stable with a 30+ pound speaker, but I do have heavy furniture in the room near the speakers so maybe 30" would be preferable to raise the sound stage above it all.
Any and all suggestions appreciated!
Old-time Stereophile
Denon PMA 2000IVR
Denon DCD-815
Music Fidelity V-DAC with Pyramid PS3KX Power Supply
Music Fidelity V-Link
Polk LSi9s sitting on VTI VSP Series 24 Stands
SVS 20-39PC Plus
Monster Studio Pro Speaker Cables
Monster USB Cable
Better Cables ICs
Denon PMA 2000IVR
Denon DCD-815
SVS 20-39PC Plus
Monster USB Cable
Better Cables ICs
Post edited by Canonshooter on
You want the tweeters at ear level ideally.
However, I found that I like them a few inches below ear level...
I would get the speakers in and experiment with different heights to find your spot and then order stands. -
Here are a few ideas in my thread, I landed on the Pangea's, and I'm happy. I have them filled with sand, they are very stable. As Max said, play with the height to see what YOU like. Good luck, you'll love the 9's.
http://www.polkaudio.com/forums/showthread.php?120483-Pangea-DS03-or... -
Thanks for the link!Old-time Stereophile
Denon PMA 2000IVR
Denon DCD-815
SVS 20-39PC Plus
Monster USB Cable
Better Cables ICs
