Wire to connect 2 speakers
Ushuaia2004
I have a pair of SDA2 speakers which are in great condition.
I moved and can not find the interconnect wire which connects the 2 speakers together.
Does anyone know where to look to replace this cable?
alf
alf
Post edited by Ushuaia2004 on
You'll have to find someone willing to part with one or else make your own. Plans for an AI-1 cable are here: http://www.polkaudio.com/forums/attachment.php?attachmentid=26698&d=1186346846. Or you can look in the vintage speaker forum. Most people make their own.Turntable: Empire 208
Arm: Rega 300
Cart: Shelter 501 III
Phono Pre: dsachs consulting
Digital: Marantz SACD 30n
Pre: Conrad Johnson ET3 SE
Speakers: SDA 2.3TL, heavily modified -
Thank you! -
Is it a Blade/Blade type or a Pin/Blade type?? If it is a Blade/Blade call Polk they can hook you up, If it's a Pin/Blade then yes as Quad stated above is your best bet!!
Thank you!
