Denon Audyssey
greg2350
greg2350 Posts: 544
edited September 2011 in The Clubhouse
Just purchased the Denon AVR-1912 got it all hooked up configured it manually watched avatar on blue ray sounds great. I ran the audyssey setup WOW!!! just WOW!!! I cant believe how much better it sounds so much better sounds like I switched out the recievers to a much more expensive one. Im really impressed and blown away with the audyssey kudos to denon. Ive had older denons that sounded great but this is my first one with the audyssey. Now my $300 reciever sounds just as good or better than my freinds $1000 and up recievers.:smile:
TV: Philips 42" LCD 1080p
Front Speakers: Polk Audio RT800i
Center Speaker: Polk Audio CS1
Surround Speakers: Polk Audio R50's powered of Denon AVR
Subwoofer: Polk Audio DSW pro500
AVR: Denon 3801
DVD Player: Denon DVM 745 upscale 1080p
Sat: Directtv HD 10
Front Speakers Amp: Rotel RB 890
Center Speaker amp: Rotel 970 BX
Post edited by greg2350 on
  • stangman67
    stangman67 Posts: 2,289
    Hmmmm. Audyssey works well, but it ain't magic
  • edoggrc51
    edoggrc51 Posts: 584
    For me Audyssey XT, has worked ok. But XT32 was on a whole other level! As always YMMV.
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Quad DIY LMS Ultra subs (powered by dual IPR-7500 amps)
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
    2ch: Emotiva Stealth 8's, Airport Express
  • stangman67
    I let the XT do it's thing on my 3311 and it did an ok job, I did have to tweak a lot of the settings. For example it set the crossovers on my front and center speakers at 40hz
  • edoggrc51
    Same here, at least with XT. With the newer XT32 it was truly an automatic setup, well almost. I did bump up the LFE by 3db's. But other than that, the more I tried to tweak it, the worse it sounded.
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
  • greg2350
    greg2350 Posts: 544
    stangman67 wrote: »
    Really I thought it was some new magic trick thanks for pointing that out. Its new to me I went from from a denon avr 2500 to the 1912 so to me it was magic.:rolleyes:
    AVR: Denon 3801
    Sat: Directtv HD 10
  • rebuy
    rebuy Posts: 695
    greg2350 wrote: »
    I've had my Onkyo for a couple of months now and ran Audyssey for the first time today and it made a big difference in the way the system sounded. Like you, I was impressed so don't let the nay-sayers get you down. We watched a movie after the correction and it sounded fantastic. It's the best sound for movies I've squeezed out of this receiver.
    The RTI's are a great speaker for theater anyway. We liked it, glad you did too.
  • falconcry72
    falconcry72 Posts: 3,580
    I always set by ear; my ears work pretty well.:wink:
  • BlueFox
    BlueFox Posts: 15,251
    Is that what this means? Your ears are hearing the same level?
    I ask because the balanced ouput from my DAC is obviously a lot stronger than the SE output, so when I run balanced, I keep the volume on the preamp at about 25%, but when I run SE, I keep the volume closer to 50%.
    A good investment is a Radio Shack SPL meter. It is nice to actually measure the SPL to give you an idea what is actually going on. I like to use mine on Friday nights after drinking beer and cranking it up just to get an idea as to what level equals loud. :smile:
  • mrbigbluelight
    mrbigbluelight Posts: 9,715
    Audyssey to dial it in; my ears to tweak it.
    My ears aren't calibrated (left ear really needs to start getting with the program), so the rule is: what sounds good to me IS good.
  • kuntasensei
    kuntasensei Posts: 3,263
    Audyssey MultEQ XT is very much a garbage-in/garbage-out proposition. If you aren't using a tripod to position the mic and following common sense procedures during the calibration (and doing all available positions), you're going to get a horrible result. Also, Audyssey doesn't set the crossovers... It passes the information to the individual AVR maker's software, and they decide what the threshold is. That's why Chris Kyriakakis of Audyssey always recommends setting the crossovers back up to 80Hz for most systems (with LPF of LFE at 120Hz no matter what). Just because it detects that channel's -3dB point as 40Hz, that doesn't mean it's the optimal setting. Just make sure you don't set the crossover LOWER than what is detected, as that frequency range has not been EQ'd by Audyssey.
    Equipment list:
    Onkyo TX-NR3010 9.2 AVR
    Emotiva XPA-3 amp
    Oppo BDP-93 Blu-ray player
    Epson 8500UB 1080p projector
  • edoggrc51
    That's exactly the way I used to tweak XT. But it didn't seem to work with XT32. I've had others tell me the same thing. Basically let it do it's thing, double check levels, and bump up the LFE (if you prefer). Other than that leave it alone.
    Denon 4311ci
    MINIdsp OPEN-DRC
    XPR-5
    LS6 Line Arrays
    LS-C Center Channel
    A/V-1RS Surounds
    Panny AE-8000u
    2:35 110in Screen
    Oppo BDP-103
    Belkin PF60
    Harmony ONE
