Should I upgrade? CS200 to CS10 ? Please help
markdavid801
Hello
I have an older surround setup with 4 R40's and a CS200 Center channel speaker.
Assuming all receiver settings are correct, I have noticed that the center channel speaker volume is slightly lower in volume. Would it be best to upgrade to the CS10? Or should I just up the center channel speaker output?
Thanks for your time.
MD
MD
Post edited by markdavid801 on
The performance from the R40's sound great, with no complaints. Its just the center channel is a bit low in output.. Im worried that by upping the output of the Center channel, it will throw the staging off..
If I were spending my money, I would go to the CS20 and get the better center channel in that product line. check out the Polk e-bay site for some reasonable prices and warranty.
Cool!! Thank you for your thoughts. I will do some research on that product!
Thanks again.
