Polk LSiM703 Frequency Response Graph
parimento1
Does anyone know how I can get access to that? I am considering ordering them, but would like to see that information to see how flat or colored they are.
Post edited by parimento1 on
I do not believe Polk has published a Graph for any of the Lsim series yet.
I will say that response curves only tell some of the story. -
LSi15's measured ruler flat on axis, I'd expect the LSiM's to measure similarly. I also agree on axis measurements only tell part of the story."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
What else will make a significant difference? distortion? spectral decay?
I recommend listening to them? I dunno - seems pretty simple- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
parimento1 wrote: »What else will make a significant difference? distortion? spectral decay?"He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
I remember some Thiels (2.6 maybe?) that had a horrendous response curve but sounded incredible, so, yea, response curves don't mean a whole lot. They can be helpful in thinking about bass and what type of sub you need, though.2-Channel: PC > Schiit Eitr > Audio Research DAC-8 > Audio Research LS-26 > Pass Labs X-250.5 > Magnepan 3.7's
Office: Phone/Tablet > AudioEngine B1 > McIntosh D100 > Bryston 4B-ST > Polk Audio LSiM-703's -
Thiel uses 1st order slopes, which usually has poor off axis response. Generally they work better with warm gear and/or well damped room."He who fights with monsters should look to it that he himself does not become a monster. And when you gaze long into an abyss the abyss also gazes into you." Friedrich Nietzsche
