Soldering Projeck
Mr. Sharpe
As some of you may already know I ordered a Denon DVD 2800 off Amazon a while back that was damaged during shipping, to be specific one of the boards broke inside as pictured. The seller was going to arrange for FedEx to pick it up for return but the other day he told me to just keep it. So I'm going to try and save it and put it to good use.
I have some questions before I begin. Like, What needs to be soldered? There's a picture, Those shiny Green fields, are they what need to be connected together? and those Silver parts need to be connected too right?
Home theater:
43” Westinghouse Displayer
Marantz UD-7007 Player
Emotiva MC-700 Processor
Adcom GFA-5006 Amplifier
Parasound Zamp Amplifier
Ethereal ESO-1 Power Conditioner
Klipsch RC-10 Center
Klipsch R34c Fronts
Klipsch RB-41 Surrounds
Polk audio PSW-505
Stereo:
Polk audio RTA-12c’s fully upgraded crossovers
DIY 12tc braided speaker cables
Denon DVD-5910ci Spinner
Parasound P6 Preamplifer
Parasound HCA -1500a Amplifier
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Post edited by Mr. Sharpe on
Everything that is split apart. Even the green Copper layer, you need to scrap that so you can solder it. And I would glue the board first.
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR -
I am convince disneyjoe7 means scrape, not scrap.
As pointed out, your first step would be to scrape the varnish around the entire damaged area (large enough to provide decent exposed working area for repair).
Also pointed out, your second step would be to glue the damaged area of the PCB using good glue such as epoxy.
Once the board damaged area is secure and the board is now again one solid piece, use rubbing alcohool to clean the copper pads that are exposed.
You now must reconnect the broken pads and to do so use pieces of copper foil pads of high enough gage. Use proper solder techniques to solder the copper pads to reconnect the broken copper junctions.
Reinstall the board in the unit and reconnect all wirewing and connectors in order to test your work. Using a non conductive tool, tap gently on the board (broken area) to check the reliability of your work and make sure there are no cold joints.
Once you know the board is fully operational, I would suggest you apply some sort of varnish over the repair to protect the exposed area.
The overall damage of the board is quite substantial and you have a nice challenge on your hands, however if you are patient and somewhat skillfull you should be able to repair the board.
Good luck with your project!
TKDARE TO SOAR:
Your attitude, almost always determine your altitude in life -
Yeah I figured it was scraped haha
awesome, thanks Tech. this should be a good challenge indeed. I don't know when I'll start but I'll be sure and tell all when I'm done:afroHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Parasound HCA -1500a Amplifier -
:afro AfroHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Screwed up again, thanks guys you understood what I was saying.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Instead of scraping away the resist layer you could also trace back the traces and connect wires from a soldered component.
maximillian wrote: »Instead of scraping away the resist layer you could also trace back the traces and connect wires from a soldered component.DARE TO SOAR:
Good lord. How does the shipping company do THAT to a board?
I'd be worried that the dvd drive assembly would be shot as well."The legitimate powers of government extend to such acts only as are injurious to others. But it does me no injury for my neighbour to say there are twenty gods, or no god. It neither picks my pocket nor breaks my leg." --Thomas Jefferson -
sucks2beme wrote: »Good lord. How does the shipping company do THAT to a board?
Not a clue. I will see if fixing the board will make it work. it really doesn't make a difference if it works or not when I'm done, I got a refund for it so I'm just doing it to see if I can do it I have thought about taking the Drive out but I know when I do I'm sure something will fall off of it or something, but that is a good idea.Home theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
If you want to be super-anal about it you could use a VOM to check the continuity of each connection as you repair it. Make a solder connection and then check two solder pads on each side of the break to make sure there's now a good connection. I check every part that is soldered before I trim the excess leads that it has good continuity with the next part it is supposed to be attached to. Use the diode checker function of the VOM for the "beep". It avoids cold solder joints.
Mr. Sharpe, do you have any soldering experience? If not, this is a daunting task and I realize at this point you have nothing to loose. This is not an easy task, even though it sounds simple enough.
Good luck
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
Kenneth Swauger wrote: »If you want to be super-anal about it you could use a VOM to check the continuity of each connection as you repair it. Make a solder connection and then check two solder pads on each side of the break to make sure there's now a good connection. I check every part that is soldered before I trim the excess leads that it has good continuity with the next part it is supposed to be attached to. Use the diode checker function of the VOM for the "beep". It avoids cold solder joints.
Lol, I don't need anything to be absolutely perfect, I mean if it works it works :afroMr. Sharpe, do you have any soldering experience? If not, this is a daunting task and I realize at this point you have nothing to loose. This is not an easy task, even though it sounds simple enough.
Good luck
Hey thanks, and no, I've never soldered anything before but I have a tad bit of welding experience of all things and I was really good at it, idk how that could be of use though. but like you said, I really don't have anything to lose:biggrin: I think if I can't get it fixed myself I might send it off to get it fixed or something then get rid of it. I have a Cd player for my 2 ch. and a good DVD player for my surround and am planning on getting a new one so.... yeah, soon I'll have DVD/Cd players coming out of my ears lolHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Mr. Sharpe wrote: »Lol, I don't need anything to be absolutely perfect, I mean if it works it works :afro
If it's not perfect then it won't work. This kind of work is painstaking and it needs to be perfect since you deaing with extremely small traces.Mr. Sharpe wrote: »Hey thanks, and no, I've never soldered anything before but I have a tad bit of welding experience of all things and I was really good at it, idk how that could be of use though. but like you said, I really don't have anything to lose:biggrin: I think if I can't get it fixed myself I might send it off to get it fixed or something then get rid of it. I have a Cd player for my 2 ch. and a good DVD player for my surround and am planning on getting a new one so.... yeah, soon I'll have DVD/Cd players coming out of my ears lol
That's like some who builds full sized cars saying I can build a model inside a bottle because I build cars for a living. Chances are if you attempt this and are unsuccessful the piece is done, as in no matter where you send it, it probably can't be fixed once you mess it up.
P.s. You'll need a lighted magnifier for sure and stand with aligator clips to hold the pcb while you work on it is probably a must have as well. I assume you have a schematic as well, that's pretty much a must have as well."Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
P.s. You'll need a lighted magnifier for sure and stand with aligator clips to hold the pcb while you work on it is probably a must have as well. I assume you have a schematic as well, that's pretty much a must have as well.DARE TO SOAR:
Lol great, now it sounds like I don't have a chance at fixing it! gah, I will try, Try being the keyword of course hahaHome theater:
Klipsch R34c Fronts
Polk audio PSW-505
Stereo:
Mr. Sharpe wrote: »Lol great, now it sounds like I don't have a chance at fixing it! gah, I will try, Try being the keyword of course hahaDARE TO SOAR:
