Turntable cartridge help needed
bklynNupe
bklynNupe Posts: 728
edited September 2011 in 2 Channel Audio
Hi, I just purchased a new Ortofon 2m Blue for my Pro-ject debut iii. I'm pretty sure I connected all of the wires correctly. From my left channel i get a loud hum and I can faintly hear the music. From the Right channel the music plays clear but I can hear a slight hum. :confused:
Thus far, I've switched to another source, my cd player and it works fine.
I don't have another turntable to see if it's my preamp. I'm going to try running my turntable through my phono on my avr to see if it is coming from the TT.
Any other suggestions would be greatly appreciated.
Brad
emotiva xpa-2
emotiva xpa-3
Denon 3312ci
Rtia9 /csia6 / FXi A6
Samsung LN46A650
SVS PB-12-NSD sub
Audio Research SP-9 MKIII (GNSC mods)
W4S ST250
Lsi 9 (mods)
W4S DAC-2
Mac Mini
Audio Aero Prima CD player
Pro-Ject debut
  • inspiredsports
    inspiredsports Posts: 5,502
    bklynNupe wrote: »
    Brad
    Hi Brad,
    First, what was your original setup (cartridge) and did it work perfectly?
    As you know, the wires that run through the armwand are incredibly fragile, especially where they connect to the cartridge, make the 90 degree bend down into the base, and connect to the larger phono output wires.
    The first place to check (with a bright light and maybe a magnifying glass) is where you connected the left channel wires to the cartridge. Just having worked with those tiny wires right there could have broken something loose.
    A separate ground from the metal portion of the turntable base to ground may also be necessary. I don't know a lot about Ortofon cartridges, but I remember one case where a Shure of mine was silent, but my moving to a Grado caused hum that a separate ground wire cured.
    Conrad Johnson PV-5 w/mods
    MF x-DAC V8, HAInfo NG27
    NAD SS rigs w/mods
    GIK panels
  • bklynNupe
    ok, after returning my stock ortofon 5m , i still had the hum. I fiddled with one of the wires and the problem was solved . i returned my new cart. and it fine as well.
    So does this mean I have a short and need new wiring in my tone arm? If so, were can i get this doe?
    Thanks.
    emotiva xpa-2
    emotiva xpa-3
    Denon 3312ci
    Samsung LN46A650
    SVS PB-12-NSD sub
    W4S ST250
    Lsi 9 (mods)
    W4S DAC-2
    Mac Mini
    Pro-Ject debut
  • inspiredsports
    bklynNupe wrote: »
    Thanks.
    There is most probably a break in one of the left channel wires unless the inside of the clip from the wire to the cartridge post was just corroded a bit. Your pushing it on and off the the cartridges might have cleaned it up.
    Replacing/resoldering dekicate tonearm wire can be like performing brain surgery. I've never sent anything out myself, so maybe someone else here who has can chime in.
    NAD SS rigs w/mods
    GIK panels
