LFE/RCA Question
snake10566
snake10566 Posts: 2
So I have a quick question. I just ordered the psw505 sub from polk and noticed it has both lfe and rca inputs. My setup is I have my computer and tv and surround system together. So when I am on my computer from my monitor, my stereo is active. When I am on my tv, my surround sound is active. Could I plug in both the lfe and rca in the back of the sub but only one would be giving a signal at a time (depending on which I am using). Would that be ok? Or is that gana freak out the sub or something?
Thanks in advance!
  • Erik Tracy
    Erik Tracy Posts: 4,673
    edited September 2011
    snake10566 wrote: »
    Thanks in advance!
    Welcome to Club Polk.
    Yes, but make sure the 'other' source is turned *off* which listening to the active one you are on. Don't have both your computer and your tv on at the same time.
  • snake10566
    snake10566 Posts: 2
    Ok! Thanks! They wont be on at the same time bc when I switch over to my tv it puts the audio through the hdmi on the video card. Which goes to my tv, then goes to my receiver (through optical).
