Best SW for Monitor 70 2.1 system?
Hi,
I have a HK 3490 on the way to power my Monitor 70's. Also have a PSW10 SW which I think may be overwhelmed by the M70's. Would a bigger, louder SW be a better fit with these tower speakers?
Thanks!
Thanks!
HK 3490, Pair Monitor 70's (series II), PSW505
Post edited by paulgj on
Yeah, the PSW 10 won't do it!
If you're on a budget, check out the PSW505 at newegg.com
If you can afford just a bit more...and you want to stay Polk, you can't do a whole lot better than the DSW Pro 600.
Good Luck!
+ PSW505 or BIC F12 for around $200
thanks! around $200-250 is my max, how does BIC F12 compare to PSW505?HK 3490, Pair Monitor 70's (series II), PSW505
+1 on the 505.Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
-Jimi Hendrix -
Another vote for the PSW 505.
Ive heard a lot of good things about the 505. I need a new sub so bad too haha but im going to save a little more and get an Epik. Ive heard nothing but the best from these things, and for the price theres really nothing better out there.
The Legend $499
Great starter sub from them
Now if you have the money, or can really save up (which im trying haha)
The Empire $799 This is what I want, would totally be mind bending to get this
And even 2?!?! SOOOO much base.
Theres a good video review somewhere of these things, u should try and check it outHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
mole'
leaning torwards the PSW505. What is the recommended method to connect to a HK 3490 (which has a sub-out) ?HK 3490, Pair Monitor 70's (series II), PSW505
Just run a subwoofer cable from the sub out on the HK to the back of the 505. Set your speaker size to small on the HK. The 505 sounds great and is a real bargain.
