Audio Electronic Supply SET II Amp
zingo
This is a copy of Nelson Pass' Zen amplifier that was commercially sold for just a short time before the amp got pulled for copy right reasons. It uses the upgraded Zen circuit, and is the best sounding SS amp I've owned at only 15wpc. I recently checked and tighten up all the connection and it's running great and sounding even better. It had a hum when I first got it, but fixed that by tightening up the connections on some caps, and ensuring proper grounds. On my last listening session I temped the fins at 155 degrees; nice and hot for a two MOSFETs per channel class A design. This amp sounds fantastic with my Klipsch horn speakers, but sounds great on any moderate sensitivity speakers. I don't have the original box for it, but I can pack it well for someone who wants it shipped; but local pick-up would be preferred. $400 paypal'ed and shipped.
Post edited by zingo on
did you mean 150wpc? or is it really only 15??
Just curious because i couldnt see the point in having a 15wpc amp lolHome Theater Setup- Receiver - Onkyo TX-RZ1100
- Mains - Polk RTi A9's
- External Amps - Outlaw 2200 Monoblocks for L/R/C
- Center - Polk CSiA6
- Side Surrounds - Polk FXiA6's
- Atmos - 4 Polk 80F/X RT's
- Sub - SVS PC-4000
- T.V. - LG OLED65C7P
Wow... :rolleyes: -
It is 1 20wpc class A according to the reviews I found on line. Always wanted to try a class A, but that will need to wait for my tube amps to be completed.The Gear... Carver "Statement" Mono-blocks, Mcintosh C2300 Arcam AVR20, Oppo UDP-203 4K Blu-ray player, Sony XBR70x850B 4k, Polk Audio Legend L800 with height modules, L400 Center Channel Polk audio AB800 "in-wall" surrounds. Marantz MM7025 stereo amp. Simaudio Moon 680d DSD
“When once a Republic is corrupted, there is no possibility of remedying any of the growing evils but by removing the corruption and restoring its lost principles; every other correction is either useless or a new evil.”— Thomas Jefferson -
Goodluck with the sale Zingo! I hate you for not posting this up for sale last week.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
You need to find a better excuse Jake has been bumping this amp for a few weeks, including last week.Gears shared to both living room & bedroom:
Integra DHC-80.3 / Oppo BDP-105 / DirecTV HR24 DVR /APC S15blk PC-UPS
Living room:
LSiM707's / LSiM706c / LSiM702 F/X's / dual JL Audio Fathom F113's / Parasound Halo A51 / Panasonic 65" TC-P65VT50
Bedroom:
Usher Dancer Mini 2 Diamond DMD's / Logitech SB Touch / W4S STP-SE / W4S DAC-2 / W4S ST-1000 / Samsung 52" LN52B750
Other rooms:
Audioengine AP4's / GLOW Audio Sub One / audio-gd NFB-3 DAC / Audioengine N22
audio-gd NFB-10.2 / Denon AH-D7000 -
Really? First time I've seen it....been MIA from the forum these past few weeks.
Spent $1.5k+ last week on my car too, would've bought this amp instead to keep me in the house
Heard a SET amp (not this one in particular) with Fostex rear-loaded speakers and it was to die for.Truck setup
Alpine 9856
For Sale
Polk SR6500
Polk SR5250
That is a pretty cool piece of hardware. Note that it is not a "SET" per se as a transistor is not a triode (even though it effectively has three elements, EBC, not unlike a triode) :-P
Nelson Pass described the design as "single ended transistor". It does have a very natural sound, and it is amazing how good simple designs sound; whether tubes or transistors.
I am in no position to argue with Nelson Pass... who does know good sound and how to extract it from components.
I have never heard a bad design from NP; your speakers would only be so lucky... :biggrin:
The Aleph 3 and 30 are even better.
GLWTS, If I had even the slightest use for this, I'd probably pick it up for fun but I have 3 integrated tube amps that barely get any love and need to be rotated in and out to get any use :biggrin:
John, your post is unclear??? This is not 120wpc single ended class A, good god that would be as big as the Pass Labs XA60 chassis.
15wpc, single ended class A sounds right. The Alpeh 3/30 is 30 wpc single ended class A and is about twice the size and heatsink as this.
H9"Appreciation of audio is a completely subjective human experience. Measurements can provide a measure of insight, but are no substitute for human judgment. Why are we looking to reduce a subjective experience to objective criteria anyway? The subtleties of music and audio reproduction are for those who appreciate it. Differentiation by numbers is for those who do not".--Nelson Pass Pass Labs XA25 | EE Avant Pre | EE Mini Max Supreme DAC | MIT Shotgun S1 | Pangea AC14SE MKII | Legend L600 | BlueSound Node 3 - Tubes add soul! -
mhardy6647 wrote: »Note that it is not a "SET" per se as a transistor is not a triode (even though it effectively has three elements, EBC, not unlike a triode) :-P
And if the rail voltages are the same as the ZEN then 15 watts is a little optimistic,more like 10 ish. -
You could be right Fred. Specs quote 20wpc, but no matter what, it's a great sounding amp that can drive most speakers.
You could be right Fred. Specs quote 20wpc, but no matter what, it's a great sounding amp ....
Sorry Jake I in no way meant to diminish the amp,and agree that if it sounds like the Zen (which it should)it will be a very sweet and musical sounding amplifier.
No worries Fred as I only assumed the best. Thanks for the kind words about the amp, and I hope this will stir up a little more interested in this beauty:
$375 shipped to your door CONUS -
grrr I would love to try this but seeing none of my speakers would do well with that little power won't work. Someday when I get into more eff speakers lol. GLWTS it looks like an amazing piece.
The amp is really only limited in low impedance speakers; electrostatics, panels, etc. Low sensitivity is not much of an issue especially if you have a well paired preamp. 4 ohms is safely the lowest nominal impedance for this amp as long as the speaker doesn't have low dips.
Just curious because i couldnt see the point in having a 15wpc amp lol -
Very true. The best amp I've ever used was my 9wpc 300B amp. Topology and build quality have far more to do with sound quality than power.
YEAH Jake
