using sr5250 crossover on sr6500 driver??
dischris
hi,
i somehow lost one of my SR5250 drivers and have a set of sr6500 drivers. my question is, can i use the sr6500 speakers on the 5250 crossover? i know they are different, the tweeter is the same from my understanding. what might happen if i do this. i guess there is a different crossover point? i will be running them in high pass only. i have a subwoofer and running the components with a old soundstream amp which will be in hi pass mode. any input would be great or even better if someone has a sr5250 driver for sale let me know! thanks
Post edited by dischris on
I don't know the crossover design well enough to comment on any specifics. Contact Polk directly to see if they have raw drivers for sale. I think that even though the speakers are not still available as a component set, I have heard others say that the raw drivers are still available.
It'll work fine, probably better. The cutoff for the mids is higher and that's a good thing. I always got better results running my SR 6's up pretty high.polkaudio sound quality competitor since 2005
Mac, what's "pretty high"?2008 Nissan Altima
Kenwood DNX 5140
Arc Audio IDX and XEQ
Polk Audio SR6500 active and SR124-dvc sealed
Polk Audio PA500.4 and PA1200.1 -
3-5khz. Crossover point will also depend on the tweet you're running. Eg the SR tweet which is a RR has great highend extension but struggles below say 3khz. So if you're running this tweet you would normally xover in the 3-5 range. I swapped the RR for the Scans that have a fs of about 700hz. I now cross my mids(SR6.5) and tweets at 1.6khz.
If you have a ton of dsp like Mac does you can play around a lot more. But typically a lower xover point will help with imaging while a higher xover point will help with tonality at some loss in focus and clarity of the image. For the level of dsp I have, I find 1.6-2khz as a good compromise between the two.
