EV Monitor Setry II speaker question?
The hook ups for these speakers are two screws like really old speakers had. No possitive or negative labels. Should I hook up to the screw that says 16 ohms to possitive and Common to negative? Also both speakers look identical but one says sentry II A and one says sentry II one is 8 ohms and one is 16 ohms... As I said before ,These came out of a church system. as always thanks,Darryl
Post edited by Dabutcher on
They are obviously different revisions of the same model. Those are PA speakers which means hound will vary, but will also mean they will take quite a bit of power to drive.Home:
Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
Home 2 (Playback):
Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
College:
JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII -
I guess all I need to know is the 8 ohm screw is for positive and the com screw is negative for speaker wire hook up? Anyone know this answer? thanks,DarrylMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Yes, com is always neutral/negative.Home:
Home 2 (Playback):
College:
Correct, but I'd be cautious pushing them hard. I probably doesn't matter with a robust amp, but you're putting a strange load on it. I might be wrong and it doesn't really matter, so I might be a weirdo :biggrin:, I don't like to give out bad info :redface:Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's -
Thank you for all the help.. DarrylMIT Magnum MH-750, Monster HTS 5100MKII, Sony 77" Class - A80CJ Series - 4K UHD OLED,PS4, Def Tech 15” sub,LSIM 706c, Sunfire Signature Grand 425 x 4,Parasound hca 120, LSiM 702 x 4, Oppo 103D, SDA SRS 1.2, Pioneer Elite SC63 , Pioneer Elite BDP-05 “Why did you get married if you wanted big speakers?”
Those EV speakers were used in many radio stations and recording studios for monitors. Not a bad sound for a 12" + horn.
The bottom is a port.
PS: try to find a little Fisher 30 watt tube amp to work with them. It will have impedance taps.
:biggrin:
