HVAC question
codyc1ark
codyc1ark Posts: 2,532
edited September 2011 in The Clubhouse
What would cause my coil to do this? It's an electric heat pump, I just turned it on heat for ten minutes or so, seems to be thawing pretty well, house is hot though. Should I be concerned? First time this has happened, coil was replaced about a year ago due to large leak.
Post edited by codyc1ark on
  • toucanet
    toucanet Posts: 580
    Low refrigerant may be the reason. When was the last time it was serviced?
  • codyc1ark
    toucanet wrote: »
    About a year ago, $800.00 later with the coil under warranty, it was replaced. Had a large blow-out in the coil. We did have the basement door (to the outside) open for awhile today, but not too long, if that makes a difference.
  • jbooker82
    jbooker82 Posts: 1,627
    Shouldnt the compressor cycle to keep the coils from totally freezing up? Almost like the compressor is constanly running so it just freezes up like that.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
    tonyb Posts: 33,028
    You have no coolant,and possible leaky.....
  • codyc1ark
    tonyb wrote: »
    Thats what I'm worried about, again.
  • disneyjoe7
    disneyjoe7 Posts: 11,435
    I know low refrig could do that, but I think a dirty filter could do that also.
    Speakers
    Carver Amazing Fronts
    CS400i Center
    RT800i's Rears
    Sub Paradigm Servo 15
    Electronics
    Conrad Johnson PV-5 pre-amp
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
    Sony CX400 CD changer
    Panasonic 42-PX60U Plasma
    WMC Win7 32bit HD DVR
  • nadams
    nadams Posts: 5,877
    Yes, in addition to low refridg, your filters being blocked could to that as well. Or, if you've been running without a filter (bad idea) It could be that the coils themselves are blocked.
    Ludicrous gibs!
  • codyc1ark
    nadams wrote: »
    I try to replace mine once every other month, the one inside of it was fairly dirty and has been changed, I'm going to fire it up once it's fully thawed. I'm not going to risk a large investment with no filter! Who would???
  • nadams
    nadams Posts: 5,877
    codyc1ark wrote: »
    Hey, for all I know, you haven't looked at it since you had the work done to it :wink:
    I had to change out the filters in my dad's forced air unit about 6 months after they built the house, because he didn't think about it... His old house was hot water baseboard and had no filters. With two dogs in the house, the filters were packed solid.
    Ludicrous gibs!
  • toucanet
    toucanet Posts: 580
    Has anyone had their R-22 refrigerant system retrofitted with the R-421a refrigerant system?
    HVAC businesses here in metro Atlanta do not mention this R-22 alternative; they aggressively push to install new systems with the Puron 410a refrigerant... for obviou$ rea$on$.
  • toucanet
    toucanet Posts: 580
    I should also mention that in addition to the R-421A Retrofit, there are many other Refrigerant Retrofit options to consider.
  • disneyjoe7
    R-22 is being phased out, so this why they wish to replace the system. Does any company wish to retrofit your system near you?
    Speakers
    CS400i Center
    RT800i's Rears
    Electronics
    Parasound Halo A23
    Pioneer 84TXSi AVR
    Pioneer 79Avi DVD
  • kefranklin
    kefranklin Posts: 141
    That is from either low airflow across the coil or low refrigerant. Another option is that they still make R-22 units, you simply have to charge them after you get them. That is nice for when someone just needs to replace a coil or compressor and they do not need to replace an entire unit.
  • JimKellyfan
    JimKellyfan Posts: 696
    You could also have blockage in an **** tube or facsimile thereof, raising pressure and freezing up. What is make and model of unit you are working on /looking at ?
    Onkyo TX-NR636
    Main - polkaudio Monitor 60's
    Center - polkaudio CSI A6
    Sub - polkaudio PSW10
    Sub2 - polkaudio PSW505
    Surrounds - polkaudio Monitor 40 series II
    Front Height - polkaudio Monitor 40's
    Audio Outdoors
    Pioneer VSX 406 - polkaudio Atrium 5
    Shed
    Sony junker str-dn2010 with Sony bookshelf floor models and polkaudio R150's
    Shed 2
    Nakamichi soundbar
