Help on rears and sub
didibrink
didibrink Posts: 5
edited September 2011 in Speakers
Hello everyone, this is my first post. I am getting a house built and im putting together my first mancave. This is my eqipment I have so far:
Reciever-Onkyo 709
Center-Polk Audio CS20
Fronts-M60s(may upgrade to M70s)
Panamax M5100
Im debating on what kind of surround and rears to get though i already have a set of M40s. Im looking for advice on what kind of sub in a $200-300 budget and rears to purchase.:confused::confused::confused:
Post edited by didibrink on
  • drummer86
    drummer86 Posts: 441
    keep the 40s and spend it all on the sub. Others will recommend the best subs to get. Be warned, if you go with the m70's you're going to want a to get a separate amp to really make the upgrade worth it. You should be happy with the m60s for quite a while. They're very decent speakers for TV and HT.
    Display: LG 47" LCD | AVR: Marantz SR5005 | BD: Panasonic BDT-210 | CD/SACD: Oppo 980 |
    Amps: Rotel RB-990bx | Marantz MA-500 | Speakers: Totem Mite : Totem Mite-C : RC60i | Sub: HSU VTF-2 MKIV
    HK AVR635 | Polk R30 | Sony DVD/SACD Player
  • didibrink
    didibrink Posts: 5
    thanks alot drummer86. would it b recommended to get a 2nd set of 40s to make it 7.1
  • teamjhertz
    teamjhertz Posts: 361
    Only do 7.1 if you have the proper room for all the speakers. If not, do a 5.1 set up. It will sound best in the room. I would focus on a sub purchase and then worry about the rest after you have the sub
  • djperez81
    djperez81 Posts: 388
    I would use the 40's as rears and just keep it a 5.1 till you can get a seperate amp, when your drive all 7 channels on your 709 it greatly diminishes the wpc. I would spend my money on a good sub or even a nice 3 or 5 channel amp.
    Music doesn't lie. If there is something to be changed in this world, then it can only happen through music.
    -Jimi Hendrix
  • jbooker82
    jbooker82 Posts: 1,627
    I dont know. Maybe the newer Onkyo's dont drop off as bad.
    Take this TX-NR807 for example.
    Onkyo rates is at 135 wpc with 2 channels driven.
    http://www.onkyousa.com/model.cfm?m=TX-NR807&class=Receiver&p=s
    Home Theater Mag rates it this way.
    http://www.hometheater.com/content/onkyo-tx-nr807-av-receiver-ht-labs-measures
    0.1% distortion 105.5 watts 5 channels driven
    1.0% distortion 122.0 watts 5 channels driven
    Turn on the rear back surrounds for a 7.1 and it gets worse.
    0.1% distortion 29.9 watts 7 channels driven
    1.0% distortion 33.0 watts 7 channels driven
    Falls off pretty bad when powering a 7.1 system
    Now look at the newer versions. Take the Onkyo TX-NR609 for example. This would be considered the newer version, but little brother to the TX-NR807, TX-NR808, TX-NR708.
    Onkyo Rates it at 100 watts 2 channels driven.
    http://www.onkyousa.com/model.cfm?m=TX-NR609&class=Receiver&p=s
    Home Theater Magazine
    http://www.hometheater.com/content/onkyo-tx-nr609-av-receiver-ht-labs-measures
    Five Channels Driven
    0.1% distortion 81.0 watts
    1.0% distortion 95.1 watts
    Seven Channels Driven
    0.1% distortion 77.7 watts
    1.0% distortion 88.9 watts
    It appears that the newer Onkyo's do not fall off as hard as the older ones do when you power a 7 channel system.
    AVR: Onkyo Tx-NR808
    Rear: FXI A4
    Sub: Polk DSW Pro 660wi
    TV: LG Infinia 50PX950 3D
    IC: AudioQuest Black Mamba II
