POLK RM 4300 Satellite Speakers Mounting Options
fchida
fchida Posts: 1
edited September 2003 in Speakers
Hi Y'all
I just bought my first Polk RM 7600 Home theater speaker system. These come with POlk RM 4300 Sat Speakers and these babies are fairly large for SAT Speakers and I am planning to wall mount them. So here are my questions.
1. Is it better to wall mount these speakers or put them on speaker stands?.
2. Do you guys know of any compatible speaker wall mounts otherthan the one sold on the POLK website. I have a problem with the one available from Polk website, it says that one may have to drill holes in the spaker cabinets to mount them. Is it safe to drill holes in the cabinet. I am not a big fan of that option?.
Need Help. Thanks in advance.
Feroze
Mit 65411 TV
POLK RM 7600 HT system
Sony DVD player
ONKYO TXSR701 Receiver
Feroze
Post edited by fchida on
  • fireshoes
    fireshoes Posts: 3,167
    You should be ok with the drilling option. It's scary sounding but not really that bad. ;)
  • dave shepard
    dave shepard Posts: 1,334
    I bought the sound gear speaker mounts from BB. They hold up to 8Lbsat. speakers but have ones that hold more $29.95, they have an assortment of mount adaptors so you won't have to drill any holes.
    Hope this helps,
    Dave
