LSI9 watts requirement
New to the separates world.
I have read over and over in this forum that the LSI9's need a lot of power to perform well. What exactly is consider "a lot" of power in watts/ch? 100, 200, 300, 1000?
Post edited by fyrn on
If you want to rock them to higher levels safely, I'd (personally) be looking at a minimum of 150 watts/rms @8 ohms; and make sure the amp is fully capable into 4 ohms. If you're going to listen to them at strictly low to moderate levels, less power could be used, but should still be stable into 4 ohms. At any rate, a high current amp is a must.
Now the "variables":
1. Room size
2. How close to the speakers will you be
3. Define "loud"
4. Room acousticsSource: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
The answer is 157.6 watts
. Just kidding, but typically with these the more clean high current power the better. I'd go quality over quantity for sure, but 200wpc @ 4ohms isn't a bad place to start. But Steveinaz is right about all the different variables than come into play. -
There are plenty of 2 ch amps out there that do 200w/ch @8ohms and roughly 300w/ch at 4 ohms that will do the job well. Look for something like that and you will be good ;-)Living Room 7.1 HT Rig:
M70 | CS2 | M60 | Atrium5 - Surr. | SUB - Emotiva ULTRA12 + Tara Labs sub cable | Pioneer Elite VSX-52 | Parasound HCAs 1000A | Sony BDP-S790 | Belkin PureAV PF60 | MIT Exp2 Wires
Bedroom 5.0 HT Rig (Music/Movies/Gaming) :
LSi9 | LsiC | Lsi/fx | Marantz SR7002 | NAD T955 | Sony BDP-S360 | Belkin PureAV PF30 | AQ Blue Racer II ICs & AQ Type 4 wires | PS3 -
If At any rate, a high current amp is a must.
This begs another question what is a "high current"" amp? Is there another spec I should look at other than wpc into 4ohms or is "high current" just a marketing phrase -
This doesn't have to be rocket science, any solid state amp in the neighborhood of 150 plus watts will work fine. Tube amps is another story but we aren't going there...are we ?
You also failed to mention if they will be used in a HT or music environment, the size of the room, or if you are looking for a 2 channel or 5 channel amp.
In another thread you posted about which amps are better. Thats up to the individual listener. From what people around here use, Parasound,B&K, Adcom, Carver or Sunfire, would be good places to start with the Emo bringing up the rear. Doesn't mean the emo won't suffice, just SQ preferences by those using the above mentioned are geared more towards the brands I mentioned. Tons of other brands too that people use, just comes down to personal preference. Thing is, pick one and get your feet wet. SS amps can last along time, but once you start hitting the 15-20 year old amps, usually some refurbishing needs to be done so take that into consideration.HT SYSTEM-
lsi 9's -
mole'
Mole--
You'd have enough headroom that you'd likely hear compression of the soundstage before you'd do any damage...remember, speakers also have a maximum SPL that they can safely output.
ADCOM is a fine choice.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
VERY generally speaking, 45 amps and up would be relatively high current output. My HCA-1500A is 60 amps. "Wattage" ratings are where you're likely to run into marketing hype on lesser equipment.
For whatever amp you're looking at, look for a 4 ohms rating on output power in the specs; if it's listed, and it's a respected brand, you're probably good to go.
Remember, as resistance (ohms) goes down, current flow (amps) increases; but the amp has to be robust enough to be able to deliver the amount of current necessary to accomodate the load---or lack of.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Source: Rotel CD14MkII CD Player - Speakers: Elac Debut 2.0 B5.2 -
High-current and ability to handle the lower loads.
Pretty much what everyone else stated above.Truck setup
Alpine 9856
Phoenix Gold RSD65CS
For Sale
Polk SR6500
Polk SR5250
A quick, rough rule of thumb for "high current" is an at least 50% increase in power from 8 ohms to 4 ohms using the same standard for the measurement. Amp makers do play with these numbers a little (e.g., understating the 8 ohm power so the 4 ohm looks better, using different measurement criteria for 8 ohm and 4 ohm). In general, the brands you mentioned in your other post will be "high current" under this definition. -
Not to hijack, but I have a pair of refurbished 9's on order. Any problems powering them off of a HK3490?Home:
Onkyo TX-6500MKII/Polk LSI 9's (A)Polk TSi 100(B)/Polk PSW 10/Onkyo C-S5VL/Technics SL-QD33
Home 2 (Playback):
Dynaudio BM5A MKII/Dynaudio SUB 250MC/Audigy 2 ZS
College:
JBL LSR 2325P/JBL 2310SP/MOTU UltraLite MKIII -
Not really, just don't go banana's on the volume dial, you should be ok.HT SYSTEM-
lsi 9's -
My 3490 ran my LSi 9's fine, but my Parasound really brought out what they can do. -
What Steve said - when possible, I try to find the peak current rating on amps. In my limited experience 45amps + a decent wattage rating + the amp being solidly heavy tends to = success
I'm driving my LSi9s with a NAD c375bee integrated (c275 amp equivalent). 150w / 410w dynamic + 50Amps peak current. Totally kicks ****. Rarely turn the volume up much past 1/4.Dali Optikon 1Mk2
NAD D3020 V2
Schiit Bifrost 2/64
..the rest are headphone setups. -
which one would you prefer for the 9's? parasound 1205 or rotel 976 (biamped)
In regards to power, my HK3480 did just fine with my LSi25s as well as my LSi7s. FWIW, while the amplifier section is great, I thought the preamp section of the HK was garbage compared to the other gear I had available. Because of that, I eventually just sold it and settled for having better sound at the cost of power. Just puttin' in my .02
To the OP, That parasound would be great. Are you trying to build a home theater? If you are, that amp is perfect. If not, look for a 2-channel model. Audiogon.net is a great spot to look for used amplifiers. You can find some really beefy ones used at the same price as the lower models brand new. Give it a look!- Computer Rig -
YAΘIN MS-20L, polkaudio RT5
- Main Rig -
Pioneer SC-37, Overnight Sensations, Samsung 52" LCD
- Currently In Progress -
Curt Campbell's Uluwatu LCR, LMS Ultra Gjallarhorn, JBL W15GTi stereo subs, 2.1 entertainment system for the gf
