Polk parts MW 6501s, SW 120s, RTA 12 top hats
geppy1
geppy1 Posts: 3,075
edited December 2011 in For Sale (FS) Classifieds
I have moved some parts around and switched cabinets and have left overs All orignal Polk parts . All are in great shape and work perfectly.
4 Polk MW 6501s from July of 1985 Used in RTA 12c, 10Bs, SDAs. They have been dynamated. I can remove it if you want. Asking $29 each
A pair of SW 120 passives from 1985 Asking $20 each or $35 for the pair.
Pair of early RTA 12B top hats. In nice shape with one tiny hole on top of one of them Asking $20 each HARD TO FIND
Post edited by geppy1 on
  • drumminman
    drumminman Posts: 3,396
    edited September 2011
    Are the top hats the later ones designed to be used with the trees, or the earlier ones used with the metal pins?
    Thanks,
    Fred
  • geppy1
    geppy1 Posts: 3,075
    They can be used with either as I have had both and used them on both. The holes are the same. These came from a set with the metal pins. I may have a later one also
  • drumminman
    I bought a set 6 mos ago thinking the same thing and they didn't fit. My 12C's have the trees and the cutouts on the particle wood base of the hats for these are a little different than for the ones with the metal pins.
    The set I bought were designed for the pins. I had to remove alot of the particle board base to get them to slip over the tweeter/crossover. They sorta-kinda go on there, but not all that well :redface: So I'm looking to acquire the correct hats.
    Any chance you could flip them over for a pic?
  • geppy1
    geppy1 Posts: 3,075
    I have two sets of speakers one with pins and one with trees. They work on both i will post pictures or better yet PM with your email and I will send them to you. i do have one of the newer o0nes also. keith
  • cwsmith68
    cwsmith68 Posts: 434
    Geppy1, Is there any chance that you may still have the top hats for the Polk Rta 12's? I recently bought a pair of these and the hats were damged in the shipping by Fed Ex. I also need a tweeter (sl100). Any help here would be much appreciated.
    Thanks,
    Coley
    Main system:
    Denon PRA-1500, Denon POA-2400, Denon TU-660, Denon DCD-2560, Denon DVD-2910, Denon DRS-640, Denon DP-30L II w/DL-301 mc cart, BSR EQ-3000, DCM Timeframe 600's
  • cwsmith68
    Sorry. Sl1000*
    Main system:
