Afternarket upgrade for LSi15 speaker stand spikes
Ducati Guy
Ducati Guy Posts: 160
edited September 2011 in Speakers
hello all,
I was curious about who has replaced their stock speaker stand floor spikes on their LSi15's. The stock ones seem a little flimsy/maybe .
Are there any replacement spikes that are exact fits?
Or do replacement spikes require drilling a new hole in the bottom of the speakers(Yikes)??
Post edited by Ducati Guy on
    EndersShadow Posts: 17,692
    Ducati Guy wrote: »
    hello all,
    A bunch of us just bought these spikes (I use them on my LSi 15's)
    http://meniscusaudio.com/extra-points-p-208.html
  • PSOVLSK
    PSOVLSK Posts: 5,372
    I got some from Parts Express (partsexpress.com). You can obviously get better, but these work for me. I THINK these are the ones I got: http://www.parts-express.com/pe/showdetl.cfm?Partnumber=240-715
    No drilling, they screw right in. I had problems with one of mine, but it did eventually work.
  • Ducati Guy
    Hey PSOVLK,
    can you post a pic of the spikes on the speakers.
    Were they an exact fit, removing the old spikes and **** in the new ones.
    And no drilling.
  • Ducati Guy
    Hey guys,
    what is the thread size for the LSi15 stock&replacement spikes?
    M6(6mm) or M8(8mm)?
  • Ducati Guy
    Or is the thread size in non-metric US sizes?
    I just emailed Polk, hopefully they'll be able to tell me exactly what size they are.
  • PSOVLSK
    I'll see if I can post some pics tomorrow. Been having trouble posting pics on the forum, so if doesn't work I can e-mail them to you.
    Yes, mine were an exact fit. As I mentioned, one of mine didn't fit very well, but it was just an issue with the threading.
  • Ducati Guy
    I emailed Polk and they stated the thread size was 1/4-20 for the LSI15.
    Is that the size you bought?
  • dorokusai
    dorokusai Posts: 25,576
    Polk Thread Size - 1/4-20, for almost every Polk loudspeaker alive today.
    The solid brass spikes from Meniscus Audio, or MyeSound fit perfectly.
  • newsman
    newsman Posts: 203
    If you have hard surface, I would recommend Black Diamond Racing Cones, you can buy a thread stud in any hardware store, and they are prethreaded with the same 1/4-20 thread. They are made from composite and back so look really good under LSi base.
    On the carpet they don't work so good, because they have a round tip. So now I'm back to the stock needles :mad:
  • newsman
    newsman Posts: 203
    dorokusai wrote: »
    Polk Thread
    Mye Sound website says they no longer have cones with 1/4-20 thread...
  • dorokusai
    Yeah, sorry, you're correct. He no longer makes them. I forgot.
