Sunfire Signature Amp
LeftCoast
Architects Choice Series II
Is this the 425 watt per channel amp?
Post edited by LeftCoast on
Disregard. I got the info I needed. Thanks.
Yes. The 425 is SO much more powerful than the 400~
:rolleyes:
TNRabbit
NO Polk Audio Equipment :eek:
Sunfire TG-IV
Ashly 1001 Active Crossover
Rane PEQ-15 Parametric Equalizers x 2
Sunfire Cinema Grand Signature Seven
Carver AL-III Speakers
Klipsch RT-12d Subwoofer -
Hey TN OTD here-hope all is well with you. Saw your post on the Sunfire True Sub-. I got one and was wondering what process is necessary to tighten all the grounds? It will get a periodic ground hum that if I go up and push the amp plate it will go away for awhile?
James -
Where? and on What?
