parts for rta 12c's
soundfreak1
I'm in the parts gathering phase. I have read about a set of binding posts that _drop in" no drilling. Does anyone know the part # and source for these? Thanks for your help.
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
I am looking for parts for my rt-20p speakers can your point me in the right direction?
Don't know what parts u need but try parts express, polk, and the polk club itself, again depending on what u need.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
Don't know of any binding posts that drop in the stock bp holes without drilling.
I used Cardas CGRS (I think), the ones that are solid copper with gold plating. The drilling is easy to do."Science is suppose to explain observations not dismiss them as impossible" - Norm on AA; 2.3TL's w/sonicaps/mills/jantzen inductors, Gimpod's boards, Lg Solen SDA inductors, RD-0198's, MW's dynamatted, Armaflex speaker gaskets, H-nuts, brass spikes, Cardas CCGR BP's, upgraded IC Cable, Black Hole Damping Sheet strips, interior of cabinets sealed with Loctite Power Grab, AI-1 interface with 1000VA A-L transformer -
Was reading a thread I can't find now that just mentioned.someone having found one that fit, can't find the thread. Anybody recall this or have info let me know, if I can replace them without drilling all the better.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
