M20s to Moniter 70s Question
Ok I bought Monitor 70 Series 2 off of newegg last night. Cant wait!
Have a Yamaha 5.1 Receiver 100w per channel
PSW10 Sub
CSi25 Center -Next upgrade I think
OWM3 Surrounds
How much of an upgrade do you think the 70s will be? I'm not sure what "class" the M20s are. Are they Monitor 20s basically? Also what is the series 2 vs the normal Monitor 70?
Thanks for the help!
PSW10 Sub
OWM3 Surrounds
Post edited by Jp381242 on
I am not familiar with the M20's so I can't comment on how they would compare with the Monitor 70's. The Series II Montor's seem to be a Newegg exclusive that have real wood veneers. I have regular Monitor 70's and I am more than pleased with them. For the center speaker, you might consider the CS2 Series II that is matched with the 70's you bought. Newegg has it for 99.99 till 9/12. Great center for that price. Just make sure you have room for it as it is VERY large.
Just an FYI, the MII's do not actually have real wood veneers. It says so in the description, but it is incorrect. The only real differences are the originals had gray grills with black surrounds, and the NewEgg series II has black grills, with silver surrounds.
Other than that, they are the same.65" Sony X900 (XBR-65X900E)
Pioneer Elite SC-37
Polk Monitor 70's (2)
Polk Monitor 40's (4)
Polk Monitor CS2
Polk DSW Pro 660wi
Oppo BDP-93
Squeezebox Duet
Belkin PureAV PF60
Dish Network "The Hoppa" -
Still great speakers especially for the price!
The M70 is a big step up over the M20's. My first HT setup was M20, M10, CS10 and PSW10. Now I have M70, M40, CS2 and it is no comparison in clarity. The M70's almost match the output the PSW10 had in bass.
+1, 51dueller! JP...you'll love the 'new' set up!
I'm running m70s,m50's with cs2 series II center and watching movies at home has never been better.
