Onkyo introduces more 2 channel components - integrated amp/CD player
Danny Tse
Danny Tse Posts: 5,206
edited September 2011 in 2 Channel Audio
New stereo integrated amp and dedicated CD player announced....
09/01/11 - UPPER SADDLE RIVER, NJ (9/1/11) -- Onkyo USA announces the release of two top-quality hi-fi components armed with the technological features needed to stay ahead in today?s rapidly changing marketplace.
The A-9070 Integrated Stereo Amplifier and C-7070 CD player offer state-of-the-art design, rugged engineering, a multitude of connectivity options, and a startlingly pure sound will appeal both to hi-fi newcomers and more seasoned music lovers looking to upgrade their equipment.
The A-9070 amplifier offers four discrete modes?integrated amp, power amp, pre-amp, and split power/pre-amp?to provide great flexibility when incorporating other components into the hi-fi system. Alone, it provides ample power with a parallel push-pull amplification design, three-stage inverted Darlington circuitry, dedicated Wolfson? 192 kHz/24-bit DACs for symmetrically designed L/R channels, and four large 15,000 ?F capacitors.
To preserve signal integrity, the unit features DIDRC (Dynamic Intermodulation Distortion Reduction Circuitry). Closed ground-loop circuits and vibration-damping construction combine to produce clear sound across a wide dynamic range. An independent headphone amplifier, a phonograph equalizer, and gold-plated audio terminals/speaker posts are evidence of high build quality.
C-7070 Compact Disc Player
The C-7070 is a versatile piece of audio equipment designed to play back a wide range of audio formats while carefully preserving the integrity of the signal. The unit is engineered around this objective, featuring vibration-damping brass legs, a 1.6 mm flat base, a full-floating circuit board, a pair of Wolfson? 192 kHz/24-bit DACs, and Onkyo?s Dynamic Intermodulation Distortion Reduction Circuitry. These improvements all work to reduce noise, distortion, and interference for pristine sound quality.
The C-7070 connects to iPod/iPhone devices via the USB port, and can play music off flash-memory drives. Other desirable features include a three-stage dimmer function, a brushed aluminum front panel, a silent aluminum CD tray, gold-plated audio terminals, and headphone amplifier differential circuitry.
These two pedigree models continue Onkyo?s unwavering commitment to high-fidelity sound, intuitive operation, and superb build quality at prices that remain widely accessible. The A-9070 and C-7070 will both be available in November with suggested retail prices of $1299 and $799, respectively.
  • coolsax
    coolsax Posts: 1,826
    love the look of the integrated amp.
    Main 2ch -
    BlueSound Node->Ethereal optical cable->Peachtree Audio Nova 150->GoldenEar Triton 2+
    TT - Pro-ject Classic SB with Sumiko Bluepoint.
    TV 3.1 system -
    Denon 3500 -> Dynaudio Excite 32/22
  • brgman
    brgman Posts: 2,859
    If that sucker plays SACD you should give it a serious look.I have the CS5VL and it is a great sounding player.
    I’M OFFENDED!!!!
