New speaker day-Infinity RS-IIIa
    audioluvr Posts: 6,013
    Are they bleeding?
    xschop Posts: 5,665
    Gmgulick wrote: »
    Where can I find a pad for the mid range and Twitter
    Make one
  • Gmgulick
    Gmgulick Posts: 2
    Where can I find acoustic padding for my mid range and tweeters on Infiniti RS 111 a
  • Gardenstater
    Gardenstater Posts: 4,858
    Depends upon whether you want to find the same material or not. What did they use, acoustic foam.?
    I would get some wool felt grade F3 and anywhere from 1/4" to 1/2" thick. I would bevel the inside edge, especially if I went 1/2". Should perform better than that stock thin stuff. What is it 1/8"? McMaster Carr, Grainger etc..
    George / NJ
    Onkyo A-8017 integrated
    iFi nano iDSD DAC
    iPurifier3
    iDefender w/ iPower PS
  • la2vegas
    la2vegas Posts: 768
    The Foam Factory has a product that is very similar to the original. It comes in a sheet that varies in thickness. The original thickness is 1/8 inch thick and comes in firm or regular material.
    Clipdat Posts: 13,101
    Congratulations on your first meaningful post.
  • la2vegas
    la2vegas Posts: 768
  • engie490
    engie490 Posts: 446
    Gmgulick wrote: »
    I have RS-IIIAs and this is what I ordered from the Foam Factory:
    1/4" Solid Charcoal Regular Foam - 72"x40"
    It was $6 for the foam and $13 for shipping. Yup...those numbers are in the right spots!
    BTW, I have way more than I need. PM me and I'll send you half for the cost of shipping (i.e., what it costs me to ship to you).
    Jeff
    KEF Xq5s / Velodyne DD12 / Apollon Purifi 1ET6525SA / SST Thoebe II / Bluesound Node 130 / Oppo BDP-105D / Technics SP-15 w/SAEC WE-308SX & Ortofon AS-309 arms / Audio-Technica ART-1 & Dynavector XX2 Mk II carts
