DIY center Ideas.
polkanddie
polkanddie Posts: 224
edited September 2011 in DIY, Mods & Tweaks
I have a set of RT10s with one bad tweeter. Is there anyway to wire it to run off one crossover and still be at 8 ohms? I think it would be pretty awesome to have a center with 2 7.5in drivers. Just not sure if its doable. I might even be able to use the plastic cones on the bottom of them for rear powerports like the cs1000p or cs400....but I might just keep it simple and make it sealed. Any ideas will be greatly appreciated. especially with crossover and wiring help...thanks!!
TV- Insignia 46'' LED,1080p,120hz
Monster Power center hts3600 mk2
Onkyo tx sr 503
Rm6600 with 4 sanus stands
SUB(DIY)
Dayton HPSA500, JVC Arsenal dvc 2ohm 12" wired to 4ohms in 1.5 cu ft sealed box
extras... RT10's.rti4s.atrium 5's.
"sticking feathers up your butt does not make you a chicken"-Tyler Durden
  • polkanddie
    I might just have to do some research on my own if no one can help. I'm good with tools and making the actual enclosure but. The wiring is a bit difficult for me.
    Onkyo tx sr 503
    SUB(DIY)
  • dorokusai
    dorokusai Posts: 25,661
    Why noy use it as is now? I realize the tweeter is dead but hook it up and see what you're up against. The next thing you need to do is open it up and pull out the xover, start writing down the information from the board.
