HDMI splitter can it be done?
disneyjoe7
Could I split a HDMI signal to 2 displays?
Speakers
Carver Amazing Fronts
CS400i Center
RT800i's Rears
Sub Paradigm Servo 15
Electronics
Conrad Johnson PV-5 pre-amp
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Sony CX400 CD changer
Panasonic 42-PX60U Plasma
WMC Win7 32bit HD DVR
Post edited by disneyjoe7 on
Yes, but you can't just use a simple "y" cable. HDMI splitters are splitter/amplifiers, such as this one.2.1: PC>Schiit Gungnir MB>Schiit Freya Noval>NAD C-270>Ascend Acoustics Sierra-1, HSU STF-2 5.1: HDMI Bitstream>Denon AVR-1910>polkaudio RTE55, CS350-LS, RT3, HSU STF-2, Visio M55-F0
You can split the cable into 6 if you have a power'd split'r
Thanks Tbone, just what I'm looking for. Not even sure why they would build just a splitter if they don't work, but need something like above.
Steve
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
WMC Win7 32bit HD DVR -
I have a 4 in 2 out that I am not using anymore. If interested I will sell reasonably, or trade for something interesting.
I just need 1 in and 2 out would that work ok?
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
disneyjoe7 wrote: »I just need 1 in and 2 out would that work ok?
Certainly. The link to a new one that I think is just like it is - http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10110&cs_id=1011002&p_id=7112&seq=1&format=1#largeimage -
Ok here's what I like to do, run an XBox 360 as a media extender to a LCD tv via HDMI. Split the HDMI from XBox 360 to run LCD and feed a HDMI to RCA, to feed a modulator to feed 2 other tv's in the house on a local inside channel feed. So not looking for anything to switch in or out, but just to split A and B outputs.
Speakers
CS400i Center
RT800i's Rears
Electronics
Parasound Halo A23
Pioneer 84TXSi AVR
Pioneer 79Avi DVD
Just a FYI, I use the Monoprice splitter to run to out from my receiver to my Panasonic plasma and my projector. I've never had a problem with it, works perfectly. Here is the splitter I used:
http://www.monoprice.com/products/product.asp?c_id=101&cp_id=10113&cs_id=1011301&p_id=7522&seq=1&format=2 -
I have heard good things about that little unit. I know it sucks we can't just SPLIT the signal anymore, but HDCP and all that makes it impossible. That and the digital signal is VERY touchy! That being said, that unit does not "Officially" support HDCP... Most people say it works fine, but there are a couple people who have had issues.
DonLiving Room: Adcom GFP-750 (Upgraded), Squeezebox Touch, Oppo BDP-83, Pioneer DV-79AVi, Parasound HCA-3500 (Upgraded), SDA SRS 2 P/B (Gimpod, Sonicaps, & Mills)
Theater: Denon 4311ci, Oppo BDP-93, Parasound HCA-2205+HCA-2200II, Polk LSi9, LSiC, LSiFX, LSi7, Custom 18" TC Sounds sub with 2 18" PR, Sharp XV-Z12000, Pioneer Kuro KRP-500M (isf Enabled)
Bedroom: HK AVR354, Pioneer DV-47a, Parasound HCA-1500a, Polk LSi9 -
dcmartinpc wrote: »I have heard good things about that little unit. I know it sucks we can't just SPLIT the signal anymore, but HDCP and all that makes it impossible. That and the digital signal is VERY touchy! That being said, that unit does not "Officially" support HDCP... Most people say it works fine, but there are a couple people who have had issues.
Don
Yeah, I had a problem with my HTPC and HDCP, but I just run Anydvd to bypass and it works fine.
