Snap! Crackle! Pop!
DaveHo
DaveHo Posts: 3,580
edited September 2011 in 2 Channel Audio
Getting back into vinyl & just picked up a low use Pro-ject Debut 3 off Agon for a good price. Currently using an Audio Technica AT6012 for cleaning purposes. The issue is this. Records from my old collection which I've owned since new, & have taken care of, sound great with respect to pops & background noise. However, some of the used vinyl I've picked up, not so much. After cleaning with the AT brush they look clean & shiny, but... Is the dirt & dust on these hopelessly ground into them or will a Spin Clean make a significant improvement? Another choice I have would be the local mom & pop store which will clean them with a record cleaning machine for a fee. Trying to keep the cost down, so a Spin Clean is about as much as I would consider spending.
Thanks.
-Dave
Post edited by DaveHo on
  • brgman
    brgman Posts: 2,859
    I got the spin clean and it helped alot.I also use a demag gun and gruv glide.
    I clean new lps when i get them as well.
    Now,where is that mom and pop shop in SE PA?
    I’M OFFENDED!!!!
  • stuwee
    stuwee Posts: 1,508
    I've been using Groovy for years, the guy at the local used record store turned me on to it, and damn if it isn't the best without buying a VPI machine. http://www.dustygroove.com/item.php?id=4md7kdtrcq
    Thorens TD125MKII, SME3009,Shure V15/ Teac V-8000S, Denon DN-790R cass, Teac 3340 RtR decks, Onix CD2...Sumo Electra Plus pre>SAE A1001 amp>Martin Logan Summit's
  • DaveHo
    DaveHo Posts: 3,580
    CD Exchange - http://www.cdexchangemusic.com
    Been in business for 20+ years. They started out as a small one room shop above a local hi-fi store(Phoenix Hi-Fi). Initially it was a place to buy & sell used CDs. They have expanded over the years, but are still a pretty small operation. I've been going there since I was a teenager when they first opened up.
    -Dave
    Permit me a moment of ignorance here. Let us take a classical station in a major city, let's say NYC. And let us recall them playing some vinyl, let us assume that they have TOTL equipment and also, perhaps, a record cleaning machine or options. How many of you remember 'still' hearing more than a modicum of 'snap, crackle and pop' on such a station when LPs are the medium? I do. Am I the only one?
    cnh
  • stuwee
    stuwee Posts: 1,508
    cnh wrote: »
    Permit me a moment of ignorance here. Let us take a classical station in a major city, let's say NYC. And let us recall them playing some vinyl, let us assume that they have TOTL equipment and also, perhaps, a record cleaning machine or options. How many of you remember 'still' hearing more than a modicum of 'snap, crackle and pop' on such a station when LPs are the medium. I do. Am I the only one?
    cnh
    I do! Quite well, I used to live in NYC, and the local UofA classical station here in Tucson still plays some Lps on certain shows. I think it's more noticable during the quiet passages (obviously :tongue:). Just the same as it is in my system at home. But, I'm one of those folks who really doesn't notice after a short time if the pops are at a low level, if it's at a obtrusive level to me and can't be cleaned up it does annoy me :frown:
    And on some pieces it adds a bit of dare I say it? Nostalgia to the experience.
    :wink: Especially through a vintage Marantz phono section :wink:
  • Joe08867
    Joe08867 Posts: 3,919
    All the time, especially more obscure Jazz and Classical stuff. I think a little snap crackle pop adds character to the music in some cases.
    By the way, I have used the wood glue method and it works quite well for cleaning out most of the crap in the grooves.
  • brgman
    brgman Posts: 2,859
    DaveHo wrote: »
    -Dave
    Thanks Dave.I have seen them listed on the Record store day site but wasn't sure by the name how serious they were about vinyl.
    I will be in Mohnton in a month for the NHRA Nationals and will be sure to check them out.
    I’M OFFENDED!!!!
  • brgman
    brgman Posts: 2,859
    stuwee wrote: »
    Wow.Another cool site i didn't know about.I LOVE this joint!Always getting hooked up with great info.
    (Although stuwee it looks like Stewart id done for this years chase:rolleyes:)
    I’M OFFENDED!!!!
    SCompRacer Posts: 9,080
    If I can't get an LP clean with scrubbing and a vacuum, I'll run a hand held steamer over it. If the grooves are already damaged, nothing will save it.
  • decal
    decal Posts: 3,205
    I love Rice Krispies with bananas !!!!!!
