changing ic cables
soundfreak1
Is there a " best ' order when replacing (upgrading ) ic cables? Ie sources to preamp first or amp /pre conections . Need to evaluate the new cables so I'm thinking source first but would like some input. Thanks
Main Rig:
Nakamichi EC100 Active xover
MIT exp 1 ic's
Perreaux SA33 class A preamp
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
Post edited by soundfreak1 on
I found source and pre made the most change also speaker cables, found less change between amp and pre but a change none the less.Speakers: SDA-1C (most all the goodies)
That was me thought also. Just seeing if I'm missing anything?.thanks.Main Rig:
MIT exp 1 ic's
AQ kingcobra ic's
OPPO 83 CDP
ADS L1590/2 Biamped
MIT exps2 speaker cable -
I only ran digital cables to my pre, so I never tried IC's from the source. I know trying different IC's between my Pre and Amp made a big difference. I noticed a bigger difference trading power cables and IC's than I did trading speaker wire personally.
